d3x0r
Quote from: luc2010 on August 06, 2018, 10:50:59 PM
Hello My Friends,
where can i find :
ac source 8000 volt ( ac only not pulsed output) with 25 khz or higher??
is that variable dimmer ac source or pulsed dc?
lucky if yes,
i would love to have that monster at my hand!!
regards
luc2010
that's pretty easy... that's just a tesla coil with good insulation.
Volts is cheap... if you want current behind it that's harder :)
It might be driven by a pulse instead of a push-pull...
https://www.1728.org/resfreq.htm
     1.3509   Nanofarad  - this might be hard to get using just a mass on the topload....
0.03 H  (30mH)
25000Hz
luc2010
Quote from: d3x0r on August 07, 2018, 03:22:14 AM
0.03 H  (30mH)
25000Hz
Hi D3x0r
thank you so much!!
lifeforce-energy
Following up on my previous post, although I have still have a lot of work ahead to do, however it was satisfying to conduct an experiment this afternoon on a recently purchased neon transformer PSU (enhanced with dimmer duty cycle control) which Don Smith was fond of in his demonstration of overunity devices.
In my case I took measurements and uploaded to what I observed via Youtube today to https://www.youtube.com/watch?v=cR1rYYgOPNw
The Setup was as follows:-  Optimising the drive input for electrical & magnetic energy from high voltage & high frequency sharp edge transient spikes,  into a full diode bridge DC rectifier via a typical high voltage microwave transformer that is reversed backwards into an approximate step-down 10:1 turns configuration, instead of the usual step-up arrangement in a household microwave oven.
The adjustable knob on the neon transformer power supply alters the duty cycle waveform output, and the effects of it from the minimum duty cycle position (has the highest spark rate & intensity) to maximum duty cycle are documented in this video. This video clearly shows that setting it at 100% duty cycle you certainly do not get peak efficiency regarding maximum volts output, a well as what was also recorded from the E-Field & H-Fields as per the yellow radiation multi-meter settings.
luc2010
Hi
heres some more  questions? please
how can we rectifies the tesla output ac voltage? in tesla times, there is no diodes? how he did it?
the neon sign tranformer used for what porpuse? i cant find it in my country any ways!!
may be its not good for tesla coils? because of some internal protection?
thanks and regards
luc2010
