0 Members and 141 Guests are viewing this topic.
romerouk
@hartiberlin - Stefan
I do have a lot of trouble connecting here.I have to try different ways to stay connected.All other websites are fine.If I connect from a new ip without beeing logged in, all is fine then moments after I login the dns is not resolving overunity.com.It is the same with different internet providers,or speeds.All started about 4-5 days back.
I am running on 50mbs here, the same at home.I tried to connect using many internet providers, as I have access to many of them and all the same.
Is anyone else having this kind of problems?
Check Ban restrictions in admin panel or maybe the bandwidth with your hosting provider is not as great...
Regards,
Romero
forest
Ok.Here is my theory which I posted long time ago at energeticforum.
IMHO this is how such devices are working.
Consider that we are all surrounded by Earth magnetic field and mostly by one pole.We know that AC current and AC spark produce EM radio waves which is a waste. Quite opposite DC arc or unidirectional DC energy transfer (yes,it could be done without spark gap) create magnetic field.If that magnetic field is opposite to Earth pole we create artificial bubble due to pushing magnetic lines by two same poles.Then very abrupt collapse of such bubble (done by immediately destroying artificial magnetic field) causes Earth field reconnection and INFLOW of energy from outside to the center. It means there is only one requirement for building such device coils (except that one, there could be thousands of variations) -  collector coil should be in not inductive relation to the transmitter (a device which disturb ambient field) to avoid Lenz law.The shape of transmitter should be such as to produce disturbance which when cross crossing collector coil is generating current.
Mixing properly low voltage high current and HV low current should do the trick - produce magnetic bubble and collapse it violently.
romerouk
Quote from: forest on June 16, 2010, 08:54:17 AM
A this is how such devices are working.
Consider that we are all surrounded by Earth A field and mostly by one pole.We know that AC current and AC spark produce EM radio waves which is a waste. Quite opposite DC arc or unidirectional DC energy transfer (yes,it could be done without spark gap) create magnetic field.If that magnetic field is opposite to Earth pole we create artificial bubble due to pushing magnetic lines by two same poles.Then very abrupt collapse of such bubble (done by immediately destroying artificial magnetic field) causes Earth field reconnection and INFLOW of energy from outside to the center. It means there is only one requirement for building such device coils (except that one, there could be thousands of variations) -  collector coil should be in not inductive relation to the transmitter (a device which disturb ambient field) to avoid Lenz law.The shape of transmitter should be such as to produce disturbance which is crossing collector coil generating current.
Excellent description @forest, I have used the system without SG and it works but with  SG it works much better.I have also used carbon rods and ideed the spark is different. Carbon roads are very good  as collectors... we'll talk about that when we reach that stage
forest
Note that we do not know exactly how Earth magnetic field is generated (or rather such knowledge is very well hidden) - so our responsibility is to first UNDERSTAND ENERGY SOURCE! I do not want to  destroy our planet ! Yet I'm fully aware that current energy paradigm is very bad.We can change it ONLY BY WORKING TOGETHER without secrets.
@romerouk: you should absolutely make an adjustable spark gap since you're working on a better setup.
