0 Members and 304 Guests are viewing this topic.
stivep
My response to revelation   from the above picture:
It doesn't work- just another hoax.
it is  just reverse.
-That should be explained absolutely the other way around  :
When we decrease  the pressure to vacuum than we  turn water to ice.
https://www.youtube.com/watch?v=2ugpooGzfR8
A method  presented in the picture from above is increasing pressure during the knocking  piston with hammer in hope
that  the counteracting expanding air will create under pressure during the piston flight-off cycle, from the cylinder.
In reality the amount of heat created during contraction is  opposing any  effect of expansion and associated  with it eventual under-pressure.
From practical  stand point  any seal between cylinder and  piston  would be  ruined instantaneously.
_________________________________________
We can also perform
instant  crystallization of water  already in a freezing point.
https://en.wikipedia.org/wiki/Freezing-point_depression
called : nucleation
But that has nothing to do with the above hoax.
Here is an example of instant crystallization:
Materials:
2 or more bottles of water
Rock Salt
Large bowl filled with ice (or you can use a freezer)
Thermometer
Frozen plate of water
How to Turn Water Into Ice Instantly.
Steps:
Fill a large bowl with ice cubes, rock salt, and your bottles
Fill the bottom of a plate with water and stick it in your freezer
Place a thermometer into the ice near the bottles and wait about 30 minutes for the temperature to drop
Slowly pull the bottles out of the ice and flick one bottle to watch ice instantly form inside
Use the other bottle to slowly pour onto the plate of frozen water to create an ice pillar
https://www.youtube.com/shorts/PE01B795TnQ
The entire process of nucleation without added salt is  shown here:
https://www.youtube.com/watch?v=hd4Z86sIJGk
Wesley
Sergh
Quote from: Fabon on July 10, 2023, 12:07:55 PM
very old: (water, hammer, ice, hydrogen and oxygen)
Uh-huh, hammer.. Thor's hammer? And if you fire a shell from a cannon?
Yes, at very high pressure, water will instantly freeze at a normal temperature of 24 degrees Celsius. At a pressure of 10,000 - 15,000 atmospheres. But the pressure in the gun barrel when fired is only 3,000 - 5,000 atmospheres. It won't be enough. Not good.
If the hammer bounces: - a vacuum and steam bubbles are formed and nothing else. No hydrogen. Verified many times. Freezing of water in a vacuum is a long process associated with heat exchange with the surrounding space. Minutes, hours, depending on the volume and thermal conductivity of the vessel.
QuoteIn 1966 a NASA technician was testing a spacesuit in a vacuum chamber when the pressure dropped to the level you would experience at an altitude of 36,500 metres. He passed out after 12 to 15 seconds. The last thing he recalled was the saliva boiling off his tongue; that's because water vaporises at low pressure. He regained consciousness within 27 seconds when the chamber was repressurised to the equivalent of an altitude of 4200 metres. Although he was pale, he suffered no adverse health effects.
https://www.newscientist.com/article/mg20627561-700-maxed-out-how-long-could-you-survive-a-vacuum/
If hot metal:
Bad news: 3000 degrees Celsius is needed for thermal dissociation. You need tungsten. Iron at this temperature will not only melt but also boil.
Second bad news: the dissociation temperature of water is 3000 degrees, and the self-ignition temperature of hydrogen is only 560 Celsius. Do you think HHO will cool down to 560 Celsius and only then ignite?
So it doesn't work. In addition, the dissociation reaction is endothermic, and the combustion reaction is exothermic, as a result, the energy does not increase even by a joule.
The maximum that can happen is that the hot metal is oxidized by oxygen from the water. The liberated hydrogen will come out through the cracks and burn quietly in atmospheric oxygen, without any special effects. It will not be much, unless of course there is a piece of lithium as a metal. But will you use lithium as firewood?
QuotePsychologism is a family of philosophical positions, according to which certain psychological facts, laws, or entities play a central role in grounding or explaining certain non-psychological facts, laws, or entities.
https://en.wikipedia.org/wiki/Psychologism
pix
Quote from: stivep on July 10, 2023, 01:08:43 PM
it is  just reverse.
We can also perform
called : nucleation
Materials:
Rock Salt
Thermometer
Steps:
Wesley
Hi Wesley.
Don't feed a troll.
Fabon aka Bunk is doing the same like on russian forums.
Engaging into discussion and posting hit-and-miss ideas completely not even related to his fake device.
Don't waste your time.
Cheers,
Pix
ramset
The talent pool is deep in global open source FE community ( includes decades long LENR
Open source scientific community)
Still many old time researchers involved!
And brilliant young minds arriving daily!
Those who write nonsense of gatekeepers in Global Open source FE research community etc
Etc
Need to show how this happens in open source
Transparent venue?
Here a true open source researcher could share a gain mechanism in a build topic
Or just make a post on forum ..( in few hours hundreds..then thousands etc etc builders and replicators...
Just One paragraph...explaining gain mechanism!
Or send paragraph to Stefan for publication...
30 years of efforts ..
Many good people still trying...
Never give up !
Respectfully
Chet K
PS
There is no part of the consequences ( for hiding FE)
That is funny ...
Thanks Grandma
