0 Members and 1921 Guests are viewing this topic.
Fabon
hartiberlin, - I do not supply viruses!....
I followed your good advice: https://odysee.com/Power-Out:c (This video, is purely an experiment on this channel!...)
Youtube channel is doing all - very bad!
stivep
Quote from: hartiberlin on July 11, 2023, 03:54:16 PM
https://youtu.be/LMzPMrg9wvYVideo from Fabon, but seems he has only done the Russian translation.
Better don't open the other small file with the Zip Archive..Maybe contains some Virus ??
Have not checked, have no time
That is correct .
It was a video made  highly likely by an American-of Irish  descent ( accent) and is quite old( 20 years) ( it is not   H.264)
All formats are here: https://en.wikipedia.org/wiki/Video_file_format
Fabon didn't make  translation to it. He doesn't speak English and is using  on line translator.
As we see from  quality of his comments.
That is easy to check: If Fabon was a translator than he  has  original English file too and he can point at the  original author.
There is always a reason for requesting a download to gain  initial confidence  of something that could be published and is for free.
Video doesn't  bring any revelation.
Wesley
stivep
some explanation :
12V 7.2Ah x2 bat in series.=24V.
is connected to-  DC to AC  converter,  or it can  be a generator.
Than at  its output it is connected to  pancake  flat coil .
On the  very top - it is yet another pancake  flat coil that is connected to the load.
Both coils require tight near field coupling.
https://en.wikipedia.org/wiki/Near_and_far_field
Everything there is hectic affected by, or denoting regularly recurrent
of observing
-coil resonance frequency
https://www.teslascientific.com/products/coil-resonant-frequency-calculator/
-impedance match,              https://en.wikipedia.org/wiki/Impedance_matching
so everything is randomly affected by  experimenter body and his hands.
Which is why overall : this experimenter is pretty much confused.
Example:
If we have leading  capacitive  reactance in that particular part of the circuit we have high voltage
Similar but reverse is with current.
Electromagnetic_Induction_AC_Circuits_
Wesley
rakarskiy
For information:
Using flat bifilar coils in a device of self-propulsion principle, even starting without external electrical impulse.
https://www.youtube.com/watch?v=W4fp9J_7-JQ&t=2s
The device has been tried to understand on a Russian free energy website since 2016:
https://x-faq.ru/index.php?topic=4204.msg125861#msg125861
The author immediately stated that he did not disclose the scheme, and made the publication as a promotional video for the publication of the material on his website:
https://oldoctober.com/ru/fuelless_generator/
Attached is a schematic of a forum member with a suggestion of how the design might be organized:
https://x-faq.ru/index.php?action=dlattach;topic=4204.0;attach=85841;image
https://vfl.ru/fotos/d8722fd119602695.html
My version is a bit different. I believe that the outer coils are used as Helmholtz series coils in the resonant circuit, and the inner coils are switched on in the capacitance mode for energy extraction.
By the way, a similar principle of inductive-capacitive coupling is used in the German patent of Paul Imris free energy generator:
http://pavelimris.com/
https://patents.google.com/patent/DE19927355A1/en
https://patents.google.com/patent/DE202018004259U1/en
r2fpl
The author of this device says it's like a detector. I think he made a radio receiver that accumulates energy in bifilar coils and periodically draws energy from the system.
He says so too. He does not say what is the source of energy because everything is on the table. We know that you can have a rabbit under the table.
The need for an impulse for the initial excitation of the system, which is not strange for the electronics to start.
It would be nice to repeat it anyway, although there are already special integrated circuits for recovering energy from the environment.
As far as I know, Samsung plans to charge the battery via base stations in a similar way.
There are already patents. I don't know the numbers because I saw it in the announcements on some TV channel.
