0 Members and 196 Guests are viewing this topic.
rakarskiy
If in Kapanadze's case, in reality, the key node is a "current amplifier", then there are only two versions, one of them is the addition to the potential difference of the voltage source in the circuit. The second feature that may be overlooked, it belongs to the category of induction.
Fabon
                           English sound (original!):
Sergh
The output winding of the Kapanadze bobbin is not the secondary winding of the transformer, because a transformer 220 volts 50 Hz 5 kilowatts is impossible in such a design. It is absolutely impossible and meaningless in this device, and in other, for example, in Kapanadze's hydraulic devices.But such a bobbin works great as solenoid.
The term "Current Amplifier" was added to Kapanadze's topic by random people. I would not use such a term, as it means another device in electronic circuitry.
It would be more realistic to call this something a "pulse-stimulated AC source" or "magnetically activated AC source".
rakarskiy
Quote from: Sergh on July 12, 2023, 07:23:26 AM
A transformer, any transformer, cannot be an amplifier a priori, it is a converter and always has a percentage of losses. Volt addition is possible only in periods, or the combination of circuits on one load, where the current limiting system works in the set load. The source of volt addition can be any high voltage generator if its secondary is not directly shorted into the circuit, but through capacitive dividers. A ТТ or neon transformer for example, like Smith's. The main setting oscillator is a 220V/50Hz push-pull As you call the Kapanadze winding system "bobbin" in the form of a solenoid, so it can be a converter that acts as an induction reactor, additional induction in the circuit. This topic of my idea, I will deal with later, after completing the electromagnetic generator.
stivep
Quote from: Fabon on July 12, 2023, 07:18:25 AM
-"It was a video made  highly likely by an American-of Irish  descent ( accent) and is quite old( 20 years) ( it is not   H.264)
Fabon didn't make  translation to it. He doesn't speak English and is using  on line translator. As we see from  quality of his comments.
That is easy to check: If Fabon was a translator than he  has  original English file too and he can point at the  original"
Thank you Fabon aka Bunk. You should of give this file at the very  first. It would make Stefan work much easier
as you are on his own property( the forum) now  for free and he pays for it.
But in anyway it is not your video nor related to your own revelation.
I didn't download the file  for security reason, but  yea Yo  wanna gonna, go change ?? I keep my eye on yo..
Wesley
