0 Members and 238 Guests are viewing this topic.
romerouk
Quote from: retrod on June 16, 2010, 12:57:46 PM
Some numbers & a video.
MOT  is a OBJY2
Input Voltage : 120vac
Input current : Measured at output of variac 4.0 amps avg
Load: Six 200w 120v Lamps
Earth Grounds : First: 200ft iron pipe (water well). Second: 10 ft driven rod, copper clad
Spark Gap : Champion J-14 with neo magnet attached
Air temperature was 68 degrees Fahrenheit
MOT Temp at start 84 F
MOT Temp at end 107 F
Run time approx 4.5 minutes
http://www.youtube.com/watch?v=n7G60lVJW8Q
Good work there, do you think you have OU or at least close to OU? your total load is 1200w thinking that the brightness is over 50% then you are there or very close.
jeanna
Quote from: romerouk on June 16, 2010, 01:38:07 PM
Thank you for your suggestions. I have tried everything already,
I have another test to do to clarify what is going on with this accessing problem, this test will clarify for sure.
The thing I did that made the biggest difference for me was that I set the history to 0 days. Then I am sure to get here first.
So, even with adblock, the "what ever they are" have no history to read, so it is quick to login.
I see that Stephan turned "them" off for your account.
So, I may be saying this to help someone else.
@everyone else, please excuse the interruption on this thread,
jeanna
uservice
Quote from: hartiberlin on June 16, 2010, 12:52:39 PM
@RomeroUK,
have set you onto the no-ads membersgroup.
Hope all is better now for you.
Regards, Stefan.
that might work
e2matrix
Thank you for your suggestions. I have tried everything already, This is my day to day job, IT - Computers, I have almost 20 years experience with computers.100% the computer is virus free.I get the same symptoms on on many computers.I tried my own computers, customers computers... same thing, all ok if I don't login.If i do login it can be 1 minute sometimes 4-5 minutes and then it locks access to the site.Other computers in the network are not accessing the site once I have been blocked on one, even if I try going to the website without  login in.I have access to change the external ip and once changed all is fine for days until the login in again.Today I tried accessing via my iphone internet and... same thing all perfect until logged in.
Same here but even longer  ;D  Glad you have a handle on it then.  I have to say knowing that it may be possible someone is actually playing games.  Please let us know what you find on this.  Sorry to be a bit off topic here but if the PTB are really doing this then we need to know.
vrand
Quote from: e2matrix on June 16, 2010, 01:59:20 PM
I run 2 diffent browsers, Win7 IE8 & Opera. Both sometimes can not connect, but can connect with the "refresh" button.  Opera 10 crashes on my office machine when replying, while IE8 does not.  Home computer has no problem with Opera.
This only occurs on this site.  But at least it works  ;D
