0 Members and 195 Guests are viewing this topic.
Fabon,for IoT-devices ?
https://www.sciencedirect.com/science/article/abs/pii/S2211285520300811
At a low wind speed of 2.9 m/s, open-circuit voltage (VOC),short-circuit current (ISC) and transfer charge (QSC) of one TENG unit could reach around 270 V, 7.6 μA and 98 nC,
https://onlinelibrary.wiley.com/doi/10.1002/advs.202201098
The maximum peak power of 9.41 mW was obtained with the load resistance of 7 MΩ (Figure S13C, Supporting Information).
Compared ,1988 ! :
https://worldwide.espacenet.com/publicationDetails/biblio?DB=EPODOC&II=15&ND=3&adjacent=true&locale=en_EP&FT=D&date=19880218&CC=DE&NR=3627532A1&KC=A1#
https://translationportal.epo.org/emtp/translate/?ACTION=description-retrieval&COUNTRY=DE&ENGINE=google&FORMAT=docdb&KIND=A1&LOCALE=en_EP&NUMBER=3627532&OPS=ops.epo.org/3.2&SRCLANG=de&TRGLANG=en
[0010]
These activatable generatrice elevations can be produced by piezoelectric (pyroelectric) foils made of polyvinylidene fluoride (PVDF) applied to the surface of the cylinder as generatrice strips or lamellae. The piezoelectric film strips or lamellae are activated by electronic generators, which are well known today, such as the line deflection of a cathode ray tube, one after the other in the desired direction, activating them clockwise or counterclockwise.
In an artificial ventilated chamber ?
wmbr
OCWL
p.s.: stream flow ' looped' ? ' perpetual motion ' !?
https://www.google.com/url?q=https://rspsciencehub.com/article_5_1a203ebb3a6da50dc940935c52590ea6.pdf&sa=U&ved=2ahUKEwjBip_h6t-AAxV4dqQEHVp2CQo4FBAWegQICBAC&usg=AOvVaw3idwM4rPDHCD6pAQXe8x2Y
Quote from: lancaIV on August 15, 2023, 06:14:29 PM
Compared ,1988 ! :
[0010]
But only after systematical improvements :
1. https://m.youtube.com/watch?v=BlIM43fRp60
2. ventilator drive coil :
https://patents.google.com/patent/WO2015189722A1/pt-PT
Compared :
wind channel chamber :
ventilator,Sabyasachi coil, meets Michael Water his Wind Turbine
http://www.rexresearch.com/waterswind/waters.html
Low cost replication :
https://m.youtube.com/watch?v=H0quZDdN53M
Orbital : Magnus effect turbine       Earth : M. Water Turbine
wmbr
OCWL
When a surplus gain loop work process is defined the next step will be to compress/miniaturize this loop concept !
Back to the Marukhine hydro ram/trombe/tromp machine :
https://www.google.com/url?q=http://www.borderlands.de/turtur/pdfs_aso/RexResearch-Marukhin-Koutienkov.pdf&sa=U&ved=2ahUKEwjYqJ7UqOGAAxXWRKQEHZZVAXEQFnoECAQQAg&usg=AOvVaw1SgqnlE_zTO2YxFMU9yxLr
Cost of used materials and manufacturing from them details for
the given generator, as claim its developers, does not exceed 10EUR/kW.
2005 claim !
https://www.google.com/url?q=http://www.borderlands.de/net_pdf/NET0511S30-33.pdf&sa=U&ved=2ahUKEwjYqJ7UqOGAAxXWRKQEHZZVAXEQFnoECAMQAg&usg=AOvVaw1b9UpRuz9vptM-vFxpO1wI
Bei einer künftigen Serienproduk-
tion werden Kraftwerksmodule im
Leistungsbereich von 0.5 MW etwa
100'000 Euro kosten.
A. to correct : not 10 €/KW but 200 €/KW production?/selling costs/price !
But :  https://www.google.com/url?q=http://www.borderlands.de/net_pdf/NET0721S12-13.pdf&sa=U&ved=2ahUKEwjSquSzreGAAxWyU6QEHbtOA-wQFnoECAkQAg&usg=AOvVaw2tnlZoDJ0lyIyHlb7r11gx
https://www.google.com/url?q=http://www.borderlands.de/Links/Beschreibung-HEG-Anlage.pdf&sa=U&ved=2ahUKEwjSquSzreGAAxWyU6QEHbtOA-wQFnoECAoQAg&usg=AOvVaw2qzuxTUbUGTkqWvi5_Q-Jg
July/August 2021 price estimation !
B. 1 MW size
https://www.google.com/url?q=http://www.borderlands.de/net_pdf/NET0917druckS14-15.pdf&sa=U&ved=2ahUKEwint8CYruGAAxW_UqQEHQlDCS0QFnoECAMQAg&usg=AOvVaw0v83jjIqJmNvNO9oTWDbSt
      to  20 KW generator in a cola can size
Fabon
 lancaIV: :o to  20 KW generator in a cola can size...  :(
