0 Members and 190 Guests are viewing this topic.
callanan
Quote from: IceStorm on June 17, 2010, 11:51:19 AM
What puzzle me a bit is the ground rod. There a simple experiment people can do , place a earth ground as JNL , put some water to make it a little better conductor , put a wire on the Hot main of your house, attach it to the ground rod, there will be about 1.5-3 Amp flowing on this one wire going to your ground rod, don't touch the Rod , there will be 100-300 Watt so it become extremely hot.If you don't get any current flow, you just have the wrong wire, use the other one.
Should look like that:
             Wire
Main(+) ..........|| Earth Ground
Main(-) Not connected anywhere
There a direct coupling between the House ground and the Earth ground proved by this simple experiment.
I don't mean JNL is extracting his energy from the House but its something to take into consideration.
Best Regards,
IceStorm
This is because the neutral line of your house is bonded to earth via an earth bonding connector in the switchboard of your house. The earth bonding connector in your switchboard is connected to ground via a proper electrician's earth rod under or near your switchboard. This is how we do it here down under.
dllabarre
@callanan
Next time to communicate with JLN, ask him if he used a capacitor between the MOT and SG and what size was it?
Thanks for all the new info.
Don
callanan
Quote from: dllabarre on June 17, 2010, 12:15:54 PM
@callanan
Next time to communicate with JLN, ask him if he used a A between the MOT and SG and what size was it?
Don
Yes he did, and the diagram above has been updated.
@callanan, thank you and naudin for this disclosure.
But is it me or should the HV diode be flipped in your above circuit?
