0 Members and 1848 Guests are viewing this topic.
xenomorphlabs
Quote from: MrWolf on June 20, 2010, 06:42:45 AM
- there is NO current in the grounding (at least in the pipe-grounding), he says he was deeply insulted when authorities did come te see his invention and said that he is stealing power from the ground etc. So he did put one hand on the pipe and other hand on the ground and showed them that there is NO current.
That can not be true, the current from the pipe grounding is being measured here.
And by the way, the pipe is a much better conductive path to ground than his body, so of course he didn´t get shocked.
romerouk
Quote from: dllabarre on June 19, 2010, 11:06:39 PM
If you have an inductance meter can you take these measurements?
1) disconnect the large 6 turn coil from the other 2 coils (leave the other 2 connected to each other) and disconnect from the rest of the circuit and grounds.
2) measure the inductance of the 2 connected coils together
3) measure the inductance of the 6 turn coil
4) reconnect the 6 turn coil to the other coils and measure the inductance
I'd like to see how your inductances compare to mine.
Thank you,
Don
I don't have an inductance meter.
I have abandoned this coil arrangement as I have discovered  a better one. It was a good inspiration. Now  I use a primary and a secondary coil. Not ready to publish results as I am very busy doing  testing to this new way of utilizing Energy.
Bruce_TPU
Hello ALL,
I think that the most interesting "take away" from Mr. Wolf's narrative, two posts above, is the following....
BOTH grounds were large and filled with water.  A radiator gives great surface area and holds a large volume of water, and his other ground pipe was also filled with water.  I do not believe that it was by accident.
Using two grounds, with metal surfaces filled with water.  I will not theorize why, but would perhaps show an interesting effect if experimented with.
Cheers,
Bruce
xenomorphlabs
Quote from: Bruce_TPU on June 20, 2010, 09:26:42 AM
Hello ALL,
BOTH grounds were large and filled with .  A radiator gives great surface area and holds a large volume of water, and his other ground pipe was also filled with water.  I do not believe that it was by accident.
Cheers,
Bruce
It is certainly worth to experiment with but Kapanadze also uses other types of grounding, so it seems as if it´s more about good conductivity than the actual water itself :
MrWolf
