0 Members and 568 Guests are viewing this topic.
jermutin
Quotethis is exactly what to expect which is why Don
SMith used a variac to control his NST's.
QuoteThis can only mean JLN kapagen really is operating under resonance and not brute
force.
He no longer has the convectional linear relationship between I/P to O/P.
SOLUTION use a variac or
This is good news for my setup!
Man, I'm happy that I bid for that variac, got it cheaper than you'd get for it as scrap metal..
J
FatBird
Instead of buying an expensive Variac, try using an inexpensive Light Dimmer that is made to control Ceiling FAN MOTORS.
In my locale, they state they can control 10 AMPS, and sell for about $7.  That is much cheaper than a variac.
bolt
Spark gap still an issue on over heating and getting the right materials etc.  Strongly suggest you try 125w mercury vapor lamp as a spark gap. Tesla used these in a lot of his experiments. They are also a high power rectifier when using mercury. Need a good 15 min warm up time on high power then reduce to idle without dropping out. If you get this running on MVL then solves many problems of EMI, noise and overheating.
dllabarre
any of the old/successful Kapagen replicators around any more?
Please PM me.
I have a couple questions regarding my replication.
Thank you,
Don
aether22
Quote from: callanan on June 24, 2010, 06:34:01 AM
Here is  from JLN which maybe relevant to your assertions.
"The use of the Variac is required because I have noticed that during the startup, when I turn the Knob, the input power climb up to 900 W and then when the spark begins to start after few second the power drops while the lamps begins to bright, at this moment, the Variac knob need to turn back to lower the input power to about 210 Watts and remains stable."
I've been busy with other stuff, but I didn't use the autotransformer when I used Naudins setup, and indeed it pulled from memory about 900W.
So I guess this bit of info is critical, the trick is getting this effect he mentions.
What I have concluded though is that either something weird is going on, or Naudin has some flaw in his grounding ciruit for the metal sheet to arc to the earth as I only had that happen when I disconnected that ground.
