0 Members and 200 Guests are viewing this topic.
grizli
cosmoLV
i don`t understand relationship between Tariel Kapanadze and kapagen - these are two different things!!!
One are based on Nuclear Reactive Ferromagnetic Fields and other like Naudin is based on HV transformation and nothing to do With FE - i don`t understand this!  This is wrong thread and Kapanadze are nothing to do with Naudin...
Keep your chakras opened :)
iflewmyown
After rereading Moray's work and looking to see if maybe Kapanadze started there I found this ...
Abstract -- A resonance oscillator electric power pack for operating a flash lamp, for example, or other electrically operated device, operates without moving mechanical parts or electrolytic action. The power pack is contained in a cylindrical metal envelope and in a preferred embodiment is coupled to a relaxation oscillator and an incandescent lamp. Within the envelope, and insulated therefrom, is a semiconductor tablet having a metal base connected to the external circuit. A metal probe makes contact with a point on the semiconductor tablet and also with a cylindrical ferrite rod axially aligned with the envelope. Wound about the ferrite rod are concentric helical coils designated as a primary with many turns and a secondary with fewer turns than the primary. The primary coil is connected at one end to the probe and at the other end to the secondary coil. The leads from the secondary coil are connected to the relazation oscillator by way of an adjustable capacitor. Oscillation within the envelope is resonance amplified, and the induced voltage in the secondary coil is rectified for application to the relaxation oscillator and lamp. Selenium and germanium base semiconductor compositions including Te, Nd, Rb and Ga in varying proportions are used for the tablet.
At   http://www.rexresearch.com/ognyanov/ognyanov.htm
slapper
That's a piezo effect.
Still lots of tuning i'm afraid.
Take care.
nap
we are not alone :)
