0 Members and 197 Guests are viewing this topic.
xenomorphlabs
@Groundloop : Cool circuit !
Is it possible that simply the current provided by the 12 V battery is too low?
If i am not mistaken, a higher source current will result in higher charge current --> rate on the secondary side and hence charge the caps faster.
However Kapanadze´s last device can even use  a 9V battery to kick the thing off ???
How about to add a voltage doubler after the secondary coil? Like in a CRT flyback transfomer?
Maybe that would get the caps to the critical discharge voltage faster. Not sure if that would endanger the 1000 V rated caps though.
You talk about MegaHertz, i am quite sure that Kapanadze is running that thing at either 5000 Hz or lower, because he does have the earth ground cable as a core in there. Maybe you can simply try to insert a core into your coil and see if you can attain resonance at a lower freq?
Sergh
xenomorphlabs
this is simple Kapanadze circuit.
1. The capacity of the  lamp is too small for frequency 5000 Hz. On low frequency we do not have support point on top this Kapanadze black-box.
2. In film simultaneously used only one of grounding.
Groundloop
@xenomorphlabs,
My little oscillator is putting out approx. 1 to 2 Watt. The HV circuit I posted
will provide approx. 30 Watt. So I will test this later on. I'm going on
a >2700 Km vacation by car tomorrow and have no time to do research.
I will be back in some few weeks time. Have a nice summer. :-)
Groundloop.
hartiberlin
Mabe it has also something to do with parametrical excitation
of the big 6 turn coil as it is wound
very lightly across the core and can mechanically swing back and
forth ?
Here is a paper that describes this excitation must be
done at twice the resonant frequency:
http://www.intalek.com/Index/Projects/Research/ppc.PDF
Maybe this is why one is also hearing this extreme humm sound
at the start ?
Or does this come just from the spark gap alone ?
I wonder why the extreme humm sound is only heard for the first
few seconds ?
Any ideas ?
WHy are the lights then shining on without this loud sound ?
hartiberlin
@Groundloop,
many thanks for the HV generator.
Have a a nice vacation and come back safely.
Regards, Stefan.
