0 Members and 221 Guests are viewing this topic.
xenomorphlabs
@Sergh:
You are forgetting that the 5000 Hz (or whatever frquency) are being produced in Circuit A and then in circuit B the frequency will be converted to 50 Hz by the frequency adjuster  and the current amplifier will boost the current. The lamps wont see the 5000 Hz at all according to the patent.
And that is the real circuitry magic,  since nobody has a clue how to put a load onto the secondary without killing the resonance and it is Kapandze´s own words, the trick is to "KEEP" the resonance.
@Groundloop : Nice holidays man !
@Stefan: I have thought that maybe that loud sound is coming from a little generator maybe that starts the circuit. It is certainly a very important observation.
Thaelin
   Ran into info on winding air core coils and it stated the length should
never be more than 4 times the diameter. This insures a high Q factor.
I noticed that his copper tube coil on the outside tends to be this as
well. I feel you could get a general idea of the resonant freq of the coil
by close measurement and plug that into the calculator.
thay
bolt
This is Tesla stuff and has been replicated, published many dozens of times through out the web over the last decade. Don Smith reproduced ALL of these circuits and many more and they are everywhere for easy picking. If you research you will find Don made millions in company stock options for this technology rather then open source and very few patents but there are some around NOT filed in the  USA!! The US don't want ANY of this stuff period! This is why he sold for stock in Chinese, Russia, Arab Emirates, Brazil etc instead.
Don made devices of 50kw and 100Kw+ and sat on a kitchen table.
BUT i have no idea why but several years ago when all this come up on this site here was the reaction.
"hartiberlin:
The devices of Don Smith seem to be a fake and he also could never prove, that
they worked as claimed. He is doing the free energy scene no good with his fakes...
Regards, Stefan. "
This particular circuit is a ground differential resonance induction amplifier that is why there is TWO ground points and NO radioactive devices or other nonsense required. The input circuit is very simple high voltage  oscillator running around 1500 volts (he probably uses a car ignition coil inside this green box as easy to find anywhere) to coil cap LC resonance with a spark gap in the feed back loop of the primary. It runs in the low Khz which is why 2 earth points required to collect electrons from the ground. The secondary coil is parametric magnetic inductive coupled to the primary coil where the primary is the left hand spin voltage  exciter and the secondary uses right hand spin of the excited ground electrons collects the current.
The published circuit with 2 earth points and coils shown above the post is close but its not quite correct and wont work as shown.  It may be deliberate to stop lazy bastards making this thing without doing some homework!
In layman's terms "it sucks electrons out of the ground"
Its not very efficient but the easiest  to build with sloppy coils and performance. At HF and VHF there is no need for ground as electrons can be taken from ambient (air)  instead. This is what Don Smith did in later designs and then you can get 100kw+ from small coil with no ground.
Its closest cousin to this system is the Imoptep CFL light energizer system widely known to everyone is also Tesla based product.
hartiberlin
@bolt
I would still say, that Don Smith´s
systems never would be able to supply 50 to 100 KWatts from
the pictures I have seen from his "small" coils.
Also he never showed any working product with a load attached, as
least as I know of.
As far as I know, Don onmly showed some breadboards with
coils and caps and claimed huge outputs and that was it.
Ne never showed a pic where he drove any load with his circuits.
If you have other infos, please let us know.
Many thanks.
xenomorphlabs
My question to bolt is of a constructive nature.
Would you be willing to help build this device, so this becomes available to everyone?
In theory you seem to know a lot about this device, i have intensely studied this technology in the last week and i agree with you in every point on the function of the device, why not to get active and
let´s replicate this thing?
Have you yourself already built anything in that direction maybe?
Just my 2 cents.
