0 Members and 482 Guests are viewing this topic.
Pirate88179
If your voltage and frequency is high enough, it is acting like a spark gap and the electricity is "jumping" the gap made by the broken filament, which may not be all that far depending upon how much of the filament is missing.
This is what I believe is happening with your bulb.
Trastos
Quote from: Pirate88179 on July 26, 2010, 01:13:32 AM
Thanks for yout attention, but i got 12 lights, the rest of the lights bright normally, the voltage is 180-160 volts (bad measured with normal multimeter in AC), i think that is a effect off, high level static electricity?.
I want a oscilloscope!   :'(
Trastos
Quote from: Trastos on July 26, 2010, 01:24:51 AM
Thanks for your attention, but i got 12 lights, the rest of the lights bright normally, the voltage is 180-160 volts (bad measured with normal multimeter in AC), i think that is a effect off, high level static electricity?.
Interesting information for high voltage through materials
http://en.wikipedia.org/wiki/Dielectric_strength
And, the electric stress for a lamp that has not lost vacuum bulb, in pessimist scenario is 20kV/mm, if is a lost vacuum bulb, this electric stress go down.. to 2kV? not sure but it possible, or the voltage spike is larger than 2kV. The distance in two toasted wires is approx. of 8-10 mm.
Thanks again.
gyulasun
Is not a noble gas filled in the bulb? maybe not pure vacuum
Trastos
Quote from: gyulasun on July 26, 2010, 04:20:33 PM
Dielectric Strength of Argon is 0.56 MV/m
OK, if bulb has filled by Argon, the break down voltage is 560 V/mm.
560V/mm * 8mm = 4480 V Approx (i think that is less), are posible use the bulb like spark gap because wires are not degraded  :D
Argon and others,
use google for see the pdf, is a google security bug :S
http://iopscience.iop.org/1402-4896/13/1/007/pdf/physscr_13_1_007.pdf
http://iteso.mx/~jorgeaguilar/cap03_04.htm
Very intersting links
http://www.sciencenet.cn/upload/blog/file/2008/12/2008121510347360620.pdf
http://physics.info/dielectrics/
i see that the dielectric science of  materials is very complex.
