0 Members and 268 Guests are viewing this topic.
dllabarre
Can someone translate all the Russian in this image?
I assume the center is split copper tube/pipe inside the Ferrite core but what is on the outside?
Thanks
Don
baroutologos
@ Pirate or Stefan,
please delete the above spammer
@Dllabarre,
This is Tiger's understanding of SR's tube transformer. The ferrite core is sandwitched by a inner copper plate and an outer one. This design is quite bizzare, since HV is applied between the two plates and still a SG is working with ground reference. Actually i have seen that in one of my experiments. (RomeroUK "magnet switching")
You can maintain  a spark-gap working between two plates with HV yet a second spark-gap can be applied it between ground and negative side of plates (not positive) in case a FWBR is applied to HV source.
but i have a feeling this second spark-gap is a high frequency capacitative one and not of the same nature as the main working spark-gap bearing the main current.
Nevertheless,
What can be the gain of such procedure?
dole
Hi,
I am pleased to post some of my last experiments. Conversion runs from the battery and with only one wired to ground, it is very rude for now but is rather principle, and it is not tuned. When time arrive I will perfect the principle and investigate in resonance and ferrite.
No OU measurement but may be fundamental principle of working, SG is very small and difficult to see, and definitively no closed loop,
I think it is just balance of RCL on both sides of opposite charge, so we may just build capacity on the one side and earth will respond. Only important thing is to proper split one pole in an oscillation. But please it could be completely wrong.
http://www.youtube.com/watch?v=YzepOmT5N_8
d.
baroutologos
Hey dole,
nice Kapanadze looking like setup. A bulb is lit from ground etc. By the way cannot distinguish many things. Can you provide a detailed diagram and modus operandi of your setup?
Always interested to see... :)
