0 Members and 165 Guests are viewing this topic.
hartiberlin
@Bolt,
maybe we can extract it more easily without wire heating
via Avramenko plugs.
This is also One wire displacement current capacitor chargeup.
If we still use RF frequencies this works very well !
Charged caps can then be discharged into inverters
or into batteries simular to how Bedini is doing it to pulse
batteries when a threshold voltage has been reached.
Regards, Stefan.
jeanna
Thank you oscar and bolt.
You made it very clear.
thank you,
jeanna
bolt
Quote from: wings on July 12, 2009, 03:19:02 PM
http://www.vlf.it/kurt/elf.html
Yes its there ELF is real but i tell you the problem this guy never realized. Its the same as if i made a crystal set radio and put a meter on the diode going to the ear phone and i could measure 1 milli volt from a powerful AM station 10 miles away.
I would think AHH i can hear something but what i measure is a very weak signal!
I tell you why. Imagine you are on a small boat off the coast of Thailand when the Tsunami hit. You would feel and measure only a slight swell as the wave pass under your little bloat. What you don't realize is the its the difference in energy are relative so when measuring ground waves or ambient air waves don't try and amplify those tiny signals because you are sat ON the boat measuring the ripple. Little did you know a devastating power wave has just wrecked havoc hundreds of miles away just went right underneath you and you hardly knew.
What you need to do is excite those electrons as a signal is in effect electrons in the unnatural place moving back to a state of normality.  I only need a frequency some harmonics higher to perturb the ELF wave so that i now have created differential magnetic field between the 2 earth points. This magnetic disruption is immensely powerful and as it passes through one coil it will invoke electrons to flow in the other coil.
Same as the crystal set radio. How can i boast my tiny signals?  If you TRANSMIT you will RECEIVE and this is the basis of the super regen radio. By transmitting back on the same frequency that you wish to receive your radio aerial will grow BIG EARS of electrons which capture more and more of the weak incoming signal. It is in effect an OU device. Please don't take the literal its an example of the technology not principles.
When a coil and cap is in resonance the resistance of the circuit drops to almost zero and becomes a super conductor and this is why there is little heating in ambient electron extraction system. In fact the opposite occurs as heat is stolen from the circuit and electrons swap places. That's why its called COLD ELECTRICITY.
You can get ice and frost on the HT cable from a car ignition coil when configured to pull free electrons. Many have seen this on imoptep CFL experiments.
Its is a VARS system where volts and amps or not in the same domain. AMPS is an EFFECT they come after as a result of electrons - JOULES going back home.
At your power factor correction caps and or FWBR then you can convert these joules to real energy and now normal laws apply where if you want to draw off hundreds of amps then YES you will need huge thick cables.
On your o/p coil if magnetically coupled ONLY back to source it is NOT reciprocal and does not load the source. Becomes like a air bound diode! You can pull whatever you like:)
So this is the bottom line. RE is electrons in the earth, the sky the universe. RE is RF thats all its not swamp gas or ether or angel dust. All you have to do is shake them a bit with some volts and they will reply with magnetic field.
xenomorphlabs
@Bolt:
What do you think of the possibility to omit the spark gap / high voltage cap aspect of the primary circuit and actually run it at 12 Volt with solid state components like SCRs in the case of using RF ?
Kapanadze`s latest device is so small that i can hardly see him having huge caps inside of it and also i don´t think it is even grounded, which would solidify your explanation that the electrons would be taken from the air without the need of an earth ground in case he uses RF in that device.
I can´t link a video of it, because it has been removed from youtube !?!
bolt
Of course you can but workmanship gets a bit more fickle that's all.  Very easy though to get off the shelf laser PSU or neon PSU or even HF choke to get couple k volts out. Even diode ladders and caps get up there pretty fast. I didn't know he had a new small device buts its an obvious progression everyone makes that's involved. You know when you mastered the art the exciter can be just an 1.5v AA battery and little more then a camera flash circuit.
The hi voltage is important despite it being RF is not the same making 12 volts 50 milliwatt TX at 5 megs is quite different to 50 milliwatts 5 megs with 2k+ volts in nearfeild resonance on an air coil.
And yes thats correct over say 1 meg ground coupling becomes less and less important as higher frequency the electrons are pulled basically from the air (ambient not really air). Its still all RF as RF starts about 50khz but spark gaps are impulses which is in effect a square or pulse wave. This has energy that when viewed on a spectrum analyzer goes way way up! Much higher then SS devices. All you have to do is add a tuned circuit almost to any chosen frequency and there will be enough harmonic energy from a spark to ring that big old LC like a bell and its so simple.
When you go to SS you need to be a little more attentive to the overall design. Power fets can go bonkers if you want them to run at a few megs they often just go into parasitic oscillation and blow up. This is why SM said about the TPU you need to use tubes first for stability and understanding unless you order a very large bag of power fets at 5 bucks each and be prepared to blow plenty till you get the details worked out.
Quote from: xenomorphlabs on July 12, 2009, 08:55:22 PM
@Bolt:
