0 Members and 1584 Guests are viewing this topic.
DimaWari
@Wesley
Thanks for your honesty bro... But what is your analysis if I connect a capacitor and transformer, put one terminal to the ground and put some load..
I hope you wont find me too annoying? thanks again..
crowclaw
Quote from: DimaWari on September 02, 2010, 01:03:22 AM
@Wesley
@DimaWari,
Go ahead and try it!  Your capacitor needs to have a very high voltage rating to avoid failure, the circuit oscillates at a high frequency so may not provide a goog match up with the transformer type you intend to use... and may tend to load the circuit down! but experimenting is what it's all about. Just be careful of what you are doing though.
Pirate88179
Quote from: stivep on September 01, 2010, 04:24:35 PM
Philosophical and physical calculation:
some basic about spark:
when you have 10kg hammer  on the table it puts the pressure( vectorized force) of 10kg on the table but when hammer slipped down from the shelf  from 3 feet hight then impact will be much greater than leading force.
The direction of the force is the same but the impact is oveunity. (So what if it cost energy of gravity, who cares?. Does cost you a dime?)
Even if we subtract energy of sliding the hammer from the shelf the total impact  energy is greater.
You left out the all important amount of energy to lift the hammer up to the shelf in the first place.  When that is factored in, you will see it all balances out to energy in=energy out.  At least in this example with the hammer.
forest
About circuit potential. Imagine you have a bunch of wood boards. It is your potential to use them , maybe you would like to make a table or a chair ? Fine. No overunity here  :P
Suddenly someone pute those boards into river and made a small dam. Now they have small potential as a chunks of wood without complex structure but also they have a potential related to water flow disturbance - someone make it part of external circuit allowing to accumulate OUTSIDE cosmic energy....
stivep
Quote from: Pirate88179 on September 02, 2010, 04:59:14 AM
Very smart  answer Thank You for  your comment.
Total balance and energy loss:
The all calculation is purposely
omitting the factor of initial lifting power ,assuming that process start from the point of sliding hammer  from the shelf. And  below there is explanation  why.............
1.If you do not start to count power balance,  when measuring " insertion loss" of resonance circuit adding all energy used to manufacture the circuit  but  concentrating yourself on -(S,2,1 parameter)( very important-see: S-parameter it is forward-reflected SWR and VSWR balance of resonant circuit )
or
2.If you do not start to count balance repealing energy of the upper magnet starting from the point of assembly-manufacturing of two magnets and assembly of the vertical 2 magnets set
and
So if  calculating the actual electric and magnetic properties you start from O (Zero) Minutes Time of Any Given Time
than
Newtonian Relativity is to be applied in here.
body once put in motion stay in motion all the time
See   http://galileoandeinstein.physics.virginia.edu/lectures/newtongl.html (this link is only for patient one to dig  in it)
The point I wanted to make is that we benefit from:
1. someone/something is losing energy (initially) in order to start   the process   http://www.space.com/scienceastronomy/solarsystem/deepspace_propulsion_000816.html
but
the ion engine uses properties of space to use small amount of energy to recover  the losses.This engine does not calculate energy balance from perspective of earth but  from perspective of space environment.
Impact of accumulated  power of spark is the  the small amount of energy added to recover  the losses
and provides  initialization ACTIVATION  of ferrite.
Scalar Waves should be the explaining factor.
Thanks to Vladimir Utkin the father  my education and the most if not only one - brilliant mind One who is to be recognized  as next Einstein.
Imagine the string of light bulbs anywhere and everywhere around you everyone of them has independent internal power supply.(the magnetism and gravitation of the earth)
They operate at the same frequency.
One has send the initial signal and than each of the bulbs activate the next one.
Than communication(energy transfer) is possible  with  other "receivers" including one in "Faraday Cage"
No propagation, or the frequency shift  affects that process.
human body utilize Scalar Waves to communicate with the brain.
The whole concept of Kapanadze must than be  overseen from the perspective of Scalar Waves.
The spark is only necessary component in  inter-inner communication.
So my friend Can you comment that? Or is self explanatory?
Wesley
PS: We do not care about solar system creation process and stabilization of gravity and earth rare magnets
we just  walk on the service of the  planet and use energy of gravity (to walk) and energy of Earth Magnets
as well.
All you need my friend is  walk , use energy and do not ever pay for it( in within your life span)
