0 Members and 246 Guests are viewing this topic.
romerouk
Quote from: zen_guru on September 25, 2010, 08:01:06 AM
@dllabarre
@romerouk
what values of electronic component are you guys using?
@LtBolo
1. if this device is not using a mot, what is T1? kapanadze is using a 9V battery, but i think there is an inverter to 220V AC inside that green box or plexiglass box.
2. i will blindly replicate it and try to understand it after. i don't have the knowledge you have in this matter. i'm trying, but you can be sure i will not report any negative results. and that's because i'm sure this kapanadze generator works. if something is wrong, it will be just my fault :).
so.. some values of the component used? are you guys using a motor or not?
kindly,
zen_guru
The battery is used to charge a capacitor to a stage where we can discharge it to give the initial kick.We can even use a 1.5 volt battery for that.You don't need an inverter to charge that capacitor, there are many easy ways to do that. Regarding a list with components all I can say is that all what do here is just a replication using our view about the Kapanadze circuit, nobody has a list of components or diagram used by him. My attempt to replicate is probably different than dllabarre and many differences with Kapanadze device.We all have different problems with our replications and nobody (yet)has a fully working device.
LtBolo
By all means...build it. I'm certainly not trying to discourage attempts. Just find it frustrating when people muddy the water when they don't know what they are doing.
You can use any front end that will give you the desired drive voltage...there are literally dozens of ways to do that. A MOT is a valid way...but...since the MOT is capable of 1500W you might confuse yourself. A 9v battery will only work when you get it right.
ElectricGoose
Oh man, you guys are so far off the beaten track on this one.  It's a new direction every page.   ::)
stprue
LtBolo
Quote from: ElectricGoose on September 25, 2010, 09:45:04 AM
If you have some insights into how kapanadze's device works, I'm  sure everyone here would love to hear it. Barring that, I'm not sure that the critque is helpful.
