0 Members and 139 Guests are viewing this topic.
ramset
Thanks Grandma
ramset
bolt
I know its not the same but would this be relevant here?
Quote from: allcanadian on November 04, 2006, 05:57:10 PM
    I mean no offense but i don't think the gray device is do-able, I think it works and you could drive a car on next to no energy-- but the arc gap would screw up every wire-less network,cell phones and radio stations for miles.That's probably why they shut him down, in this day and age of infomation that kind of RF interference would not be tolerated, unless you could shield it for zero interference.
    just a thought
Thanks Grandma
bolt
IF system is looped electron acquires energy from heat , (ethereal) is where gravity equation enters as electron goes soft Time where M=MC²/vT , Time becomes retrograde creating -G
Effects are real its documented. The Sweet VTA started off weighing pounds and at 1kw weighed ounces. At higher power levels these devices can fly.  They absorb light at high density power levels and distort time. Effects noted on searl saucers underside was black when viewed from the ground.
Searl -G absorption of radiant Electron Volts estimated equivalent of 500,000 Horse Power!
For hi density use poly-phase HV HF drivers into 3 dimensional  resonance allows wormholes to open.
This is UFO technology         ....and time machines:)
First you have to learn the basics. Then you have to tame the beast because electron "theft" here are making a 4th dimension swap with another electron somewhere else in the universe. This is serious shit if you go over 50Kw you must be aware of these dangers. Local time becomes compressed around devices at these power level.
jeanna
OK Bolt,
I have been thinking about this for a while, well since I read the book on tesla's inventions, I just looked on ebay and there are some ignition coils for less than 30+10=$40.
OK, but my question is: is there a reason to get an older style over a newer or are they all going to do the job pretty well.
I am so not a car guy. I know people here would help, but it is better just to get the right thing in the first place.
What can you say?
I have been using my joule thief with one or more than one secondary and getting very great results. 450v at 5.6KHz, 220v at 33KHz,  141v at 208KHz. - all off the secondary.
If Don Smith is right, I should be able to get 450v over and over since it is coming from the magnetic pulse of the toroid and will get that as many times as I can wind another secondary.
If he is right about it.
But, he was using a spark to prove his idea too.
So, I probably should make a copy of the tesla circuit first, then make it work with the pulsing from a joule thief instead of the coil.
thank you,
jeanna
bolt
Gas/petrol cars already have a Tesla coil and spark plugs.  Not really an issue it can be tamed to become virtually invisible.
Quote from: ramset on July 14, 2009, 07:42:49 PM
bolt
