0 Members and 156 Guests are viewing this topic.
stivep
Quote from: forest on September 29, 2010, 01:22:55 PM
I like this face  ;D so do not see anything wrong using it. My theory is  ;D
I don't know Wladimir Utkin I heard something about two frequencies but I'd like to check "source" of theory.I do not understand your impatience. If I have your fluent mind and can learn every language in few days and can have nice lab and many people to help I would SMILE  ;D ;D ;D everyday
Forest do not be jumpy and bumpy I was complementing you   Don't you see it? But please Wladimir Utkin is so far the only one who know how it works.Kapanadze has a lot less knowledge than him.
You can build Kapanadze device but still you may  not understand how it works
Wesley
forest
Small correction :
Как у СР-а,Ñ,ак и у Капанадзе в усÑ,ройсÑ,ве присуÑ,сÑ,вуеÑ, преобразоваÑ,ель 12/....Both SR and Kapanadze utilaze INVERTER 12/... (probably 220V)
Только СР поÑ...оже спряÑ,ал его под сÑ,ол.But SR looks like hide it under the  table ( Wesley's comment: if you know what it is you will see it) Only SR hide this under table.
Моя пракÑ,ика показываеÑ,,чÑ,о используя исключиÑ,ельно 12 вольÑ,, приличного Ñ,ока в независимой каÑ,ушке не создаÑ,ÑŒMy practical experience shows that when 12 V is used there is no way to get high current(high energy) IN INDEPENDENT COIL
forest
Quote from: stivep on September 29, 2010, 03:25:13 PM
Wesley
other options is .. I can understand it but cannot build it ? :D
LtBolo
Tesla's 'extra coil' was outside the inductive coupling range, and was excited by other means. We've played with a small Tesla coil sitting within the electrostatic field of a big Tesla coil, but outside direct inductive coupling, using an independent ground. It gets quite active. No real sense of how the extra coil 'loads' the main coil, but it seems that if you keep it at a distance, it doesn't load the main coil. So it is clear that electrostatic fields can induce resonance pretty well. Having the two at right angles would ensure that the coupling was purely electrostatic, not magnetic.
Thinking about Cosmo's experiment....
The high voltage high frequency coil will generate a strong electrostatic field. Is it possible that the electrostatic field has a stronger effect on the magnetic domains of the ferrite than the magnetic field from the low voltage coil? Possibly affecting the ferrite at an atomic level? If it were an electrostatic effect, and not a magnetic effect, that suggests that a magnetic field could be switched off with no real power dissipation. I can think of many good uses for that. Big question is whether it is frequency dependent (atomic resonance) or field intensity dependent (big voltage). Care to comment Cosmo?
stivep
Quote from: forest on September 29, 2010, 03:36:30 PM
Small correction :
you right
Wesley
