core
Quote from: dllabarre on October 10, 2010, 08:24:06 AM
I've never seen this link posted and yes it's interesting.
Thank you,
DonL
It is a very interesting site. He did a great job. One of the pictures caught my attention. (see below) I am tempted to try out his ideas also. I wonder what the result would be if in our ferrite ring core we place a dialectic or air gap in the middle. He seems to be polarizing both halves while the high voltage covers both halves. Coincidentally there is a 'coil' in the middle of the ferrite?
Respectfully,
Core
Here is an interesting part of the article.
QuoteTo physically locate the Tesla coil somewhere else and in its place put a third coil -- an eddy current drive coil.   This coil would be driven by some kind of phase control device: capacitance, resistive capacitance, solid state, etc.  The purpose of this third coil is to create expanding and contracting magnetic fields that are in a desired phase with the electron migration induced by the high voltage emitters within the core material -- in a complimentary phase with the charging capacitor.  This would mean that this coil could be 90 degrees out of phase with the Tesla coil and would need some kind of phase control.
          Unlike Option 1, this coil's function can go in multiple directions according to the phase control.  The two extremes are:
    * The effects of the expanding and collapsing magnetic field to be completely in phase with the electrically induced electron migration caused by the high voltage plates -- totally work with the high voltage capacitor operation.
    * The effects of the expanding and collapsing magnetic field to be 180 degrees out of phase with the electrically induced electron migration caused by the high voltage plates -- totally work against the high voltage capacitor operation.
    * And then...there is any place in between.
core
Going back to the above article. Lets assume that the Spark Gap is OU like LtBolo stated. In the article what if the high voltage end was feed by a spark gap?
It was hinted by Cosmo regarding insulation. Here is some nice wording in the article:
  All high voltage insulation considerations should be taken into account.  The entire high voltage electric field isolation transformer/capacitor assembly (except for the pole surfaces) should be embedded in a high voltage non dielectric insulation material.
Can get some opinions from you electrical Guru's :)
Last but not least, the last statement in the article had me at hello. (bad pun) :(
You may notice that this device is very simple.  Because this device is so simple, it is the author's opinion that it if it works (as the author guesses), it should have been invented 80 years ago.  One person capable of this, at that time, would have been Nikoli Tesla.
Respectfully,
Core
core
On the same site look at this page. This has been spoken about before but dismissed. Maybe time to give it another look. I do believe this is the 'missing link'
http://www.i-am-a-i.org/free-energy/powerconverter.html
Respectfully,
Core
core
@LtBolo
Can I get your professional opinion on this paragraph. This sounds very enticing and may explain Tariel's device. Also note to All. The website is dated from Aug. 2000 This info appears old but simple.
___________________________________________
Physics, in the field of quantum electrodynamics, hypothesizes the existence of virtual photons.  These are potential photons with an infinite amount of potential energy.  This virtual photon explanation is used to explain the amount of physical force that can occur for a relatively small amount of electrical work with Coulomb’s Law.
    This device is an attempt to convert the infinite power potential of a virtual photon into an actual electromagnetic power drive circuit â€" electrical energy.  The idea is an attempt to amplify electrical power through the use of a VPR (Virtual Photon Reference).
    The electrical approach is relatively simple.  A single circuit that provides both current and voltage energizes almost all electrical devices; voltage and current sources come from the same power supply.  This device has two separate power supply circuits; one provides the current, while the other provides the voltage.  Assuming AC is put in, one power supply provides the current â€" is the magnetic field driver â€" while the other circuit provides the voltage â€" is the electric field driver.  The phase between these two separate AC power supplies is adjustable.
    The device mixes a high voltage induced electric field with a high current induced magnetic field into a primary of a transformer and on a plate of a capacitor.  The device has two circuits mixing in a single transformer, one a current circuit â€" magnetic field related -- while the other is a voltage circuit â€" electric field related.  The voltage is induced into the coil through capacitance and this help keeps the circuits’ currents of the two power supplies isolated.
    The idea is for secondary of the transformer magnetically and electrically sees a high voltage and high current transformer primary winding â€" a high VA primary.  This lower voltage high current secondary feeds a power load (whatever that may be) according to the VA it ‘sees’.
______________________________________________________
Respectfully,
Core
LtBolo
@Core
Incidentally, I don't think the spark gap is OU, although some do...I think the inductance drop due to resonant saturation...might...be OU, but only because Cosmo stated pretty definitively that it is. If that is the case, then, anything that you can do to 1) jack up the current to very high levels, and 2) while at high current, resonant saturate the ferrite, and then 3) stash or consume the power prior to the recovery of the ferrite, should be OU. Do so efficiently, and you may even end up with COP > 1. I do distinguish between the two. I consider something OU that is adding energy to the system, regardless of whether it is COP > 1. Although only COP > 1 is truly helpful.
Quote from: core on October 10, 2010, 02:00:43 PM
I would say that 'virtual photons' sound a whole lot like 'luminiferous aether'. Funny thing...it seems that the whole justification for quantum mechanics is to deal with the obvious truth of the aether. Since Newtonian mechanics can't work at the quantum level unless there is a power source...and we've ruled out the power source by eliminating the aether...let's create a whole new line of study that masks the truth that was known 130 years ago, by creating virtual particles...
...But don't get me started. The most likely explanation for huge reservoirs of fossil fuels buried under immense layers of sedimentary rock is a massive flood event that killed off billions of animals and deposited them in huge mass graves and then buried them in mud. Ironically though, the same science that talks about planet wide floods on Mars...which currently doesn't have much water at all...completely rules it out on Earth, where 75% of the planet is currently covered in water...and...virtually every ancient religion has a flood mythology of one sort or another. Gee lemme think...why, oh why don't we have universal free energy?
<rant mode *off*>
As for his proposal, I don't really have a specific opinion. He sounds very intelligent and it all sounds well thought out. I would simply wonder why if he truly had a strong conviction about the viability, why no experiments?
