0 Members and 379 Guests are viewing this topic.
Dankie1
Quote from: catalyst on October 10, 2010, 06:22:14 AM
@cosmo
I made the effort to read all your post on energetic forum. So many clues, hints, info, data that is spread, just need to collect. I understand your way of interaction in forum.
Do not let yourself bothered by negative voices. Like said ignore them. No need to explain yourself to anyone who don't get it still. Better concentrate only to support those who catches up and can show responses to your many probings.
In maybe a month or two, only then i can do real experiments. Now i have no chance. So it would be fine if you would stick around for a while longer.
If i'm not lazy, i will collect all hints to get a clearer picture.
Nobody is taking his words lightly , I am spending the time and money .
But Im not putting anybody on a pedestal yet .
Never fully trust of disbelieve .
Dankie1
If we go by Rhthmodynamics from ivanov then the spark is creating rapid imbalance in standing wave wich might disturbs ambient wave exchange  close to device and allowing a new wavepattern to form , frequency pulling somehow ( still visualizing ). Changing both earth and ambient exchange frequency exchange near device . Energy flows from Hi to low remember .
I believe the device compares itself to earth like earth compares itself to surrounding space .
http://www.mirit.ru/rd_2007en.htm
http://www.mirit.ru/video/008.htm
catalyst
This is some bit a concentration of cosmo's contribution in energetic forum. Since it's all spread around, it was needed to be put back together. Which is what he suggested himself ("Who listen what i'm saying couple posts back and on start in this thread , they understand principle of device and fully can make it...").
Tesla switch has nothing to do with Kapanadze device.
Parametric resonance in Tesla coil, see what Don Smith are done in his coil - it is wind on right way, only one thing is missing there, you need ferrite or iron core and right HV transformer and find the frequency by adjusting spark gap.
(21..35) KHz with small simple HV transformer with 3000v - 6000v
must use a correct HV transformer type
stay away from MOT (disturbs electromagnetic field)
3 things to drive FE device (all mandatory, else won't give OU)
1) spark gap - radiant energy - absorbing it
Important thing is method for absorb properly the energy released from process.. very important is understand what is radiant energy and as is propagated from process.. - "Energy comes from air" - Only what you need is little HV to make Born new electrons and lots of electrons forming around the wires, the second thing is to activate these electrons...
- Sparkgap is used only to put juice in tesla coil - to support voltage loop.
- important is spark gap power, like on electric lighter - it is strong and fast with great potential.
- do not put load in spark gap path
2) coil setup
deleted example - as from post #191 ("very efficient coil setup")
-with 19 ferrite rings as we all know by now
-everything is in the coil setup - actually in windings.
-it is bifilar coil but in not standard way
-Coil resonate itself and make some magnetic fluctuations
-Coil does not run using with TV HV Transformers
-Coil phenomena is that it runs around 50 ~ 60 Hz by itself
-Forget about modulations, Scopes and others - (without understanding principle this makes no sense)
-don't take energy directly from the coil like Smith design.
3) ??? (maybe exists and mixed already in above lines)
What about the significance of glass medium in 100KW setup, is it used to redirect/collect electrons from air ?
Now, if those with ready test-bench can cross-check the above guidelines and actually continue to perform suggested tests. And let's keep focused on subject.
The rest and newer contributions are in THIS topic. What to do next is to experiment and share / discuss the results here. Do you guys have frequency generators or other simple means to generate (21..35) KHz? Do you have the right simple HV generator ? Giving special attention to spark gap during process. That all should be enough to tune YOUR coil. Every coil as i understand will need it's own tuning.
What to do next after having a "hotdog toaster" ?
Quote from: wojwrobel;98186hello
i just wanted to add something :
im working on Thane Heins devices and found very similar idea with that what Kapanadz is doing !!
ok
first Kapanadze device was a rotating device right!! not solid state and here is this similarity
when you read Thane Heins patent CA2437745A1 you will find out that he uses two types of coils on one core one is high voltage coil that creates "static enviroment" that prevents current from flowing second "working" low voltage high current coil , so when magnet pas thru coil the high voltage coil blocks current from flowing in working coil and when magnets leave it releases all current buildup in working coil thats why current is deleyed in Thane generators and its propably deleyed in Kapanadze device but noboody can mesure !!!
and Kapanadz solid state device works on the same principe its simply creates "static enviroment" in working coil that holds current from flowing until primary finish work cycle....
cheers from poland
wojsciech
Quote from: cosmo-lv;98207Ok - ewerybody can make one simple experiment.
After that Guess the design of the Kapanadze/Tesla Coil :)
catalyst
I wanted to apologize once here, because that i collected material from others and thrown onto you guys. I'm aware that i should take my time and effort to do tests myself and share results here. Due reasons, i can not do so for now, so i play the role of an assistant. Hence 2 of my replies started with a "Sorry...".
exnihiloest
Quote from: LtBolo on October 10, 2010, 05:32:24 PM
While I perceive Him as father and creator, I'm reasonably sure He isn't an old white guy in flowing white robes sitting on a golden throne controlling the world with the celestial equivalent of an XBox/360. So if not that...then what?
Not an old white guy in flowing white robes, sure, but just a psychological process working in the neurons of the believers.
Unfortunately we don't know how to plug it to get FE.
:D
