0 Members and 136 Guests are viewing this topic.
Waves
LtBolo
I keep coming back to sympathetic resonance at a different frequency. Kapanadze said somewhere that you can't kill the resonance, which makes perfect sense...and is completely consistent with Tesla, who said that any power that left the coil was wasted. If you were to were to use a standard Tesla primary and secondary of high Q to build a large amount of power in the secondary, and then used a tertiary coil that was tuned to a significantly higher harmonic, say 12x...which has a big convergence of energy from the 2nd, 3rd, 4th, 6th, and 8th harmonics...would the same amount of energy that transfers from 1 to 12 be reflected from 12 to 1 via Lenz?
If not, then it stands to reason that you really wouldn't have a magnetic coupling to speak of, and the tertiary coil could drive a load to ground with virtually the same energy as the secondary, but without disrupting the secondary resonance. Long shot, I guess.
Another possibility...if the tertiary is bifilar, and is attached to wire that is quarter or full wavelength of the secondary resonance, would the electric field around the secondary induce a standing wave in the tertiary and attached wire? Like before, if the bifilar coil in the electric field will do a quarter or full wave resonance, it stands to reason that you would have a significant amount of power to ground without disrupting the secondary resonance.
Just brainstorming...
Shokac
Does anyone know how to switch 220V through the coil, and that everything goes through the inverter 12V. (cca 1A)
Or better yet to ask. How over the 12v power inverter and SR / Kapanadze / Cosmo transformer to get 220V but without any additional excitation?
Scheme?
scratchrobot
Today i finally got my ferrite toroids and i want to do Cosmo's experiment but for HV part
i want to use a small plasma globe transformer. It also has a mic, maybe i can change freq with it?
http://www.youtube.com/watch?v=4QYaR9HR-tM
Would it be powerful enough to get the desired effect?
catalyst
Quote from: cosmoLV on October 16, 2010, 08:16:26 AM
imagine a mop as kapanadze transformer, two potentials who squeeze third coil who are in middle and ground wire into middle of that transformer.
when you squeeze it, then all air is out, when you take off hand then mop bring back it's position where all air fill it again without help from the side..
I don't understand. I'm not a housewife. I don't use sponges and mops.
Come again in technical language?
