0 Members and 56 Guests are viewing this topic.
catalyst
I don't care about negative opinions. Hope you want to correct me or add your contribution or set things straight if you can think of something better.
I do however, acknowledge that most theory in my last posts was wrong. Because it's a progress. I do not know the solution, i am searching for it. The kitchen table is a mess while cooking. This is not the ready set dinner table.
In my last posts i had tried to make sense of LV circuit. It went wrong assuming the missing link to be the magnetic amplifier. Nobody contributed, except Shokac. As claimed, there should be magnetic amplifier in the LV circuit. It is not so. The mag amp schematic above functions like by using small amounts of current/voltage and a potentiometer, one can control AC current amount through load (the lamp).
http://www.youtube.com/watch?v=DBX1-POuJMw
The LV is not a mag amp in that sense (current limiting/contolling type). It is also not the old style DC-AC circuit. Is looks alike, but is not. The DC-AC circuit:
http://www.free-circuit.com/wp-content/uploads/2010/05/DC-to-AC-with-IC-300x180.gif
It has similarity, like the 2700uF cap. in cosmo's test setup.
Difference is that the bifilar windings are included. It also don't work with 50 Hz like in classic DC-AC. Clock rate must be high. Would you turn a mechanical generator at low speed like 50 turns per second ? It must be in thousands to deliver juice.
Think what LV's function must be. If you don't like my suggestions, then give better ones, but please do not negative comment on my thoughts. Correct them, but do not stampede them. I have not seen one comment on the function of LV part from others. Hint from cosmo perhaps ?
LV coil should create toggling electromagnet with the ferrite, in fast cycles. It must use high currents maybe 1-2-3-4 Amp (?) to cause big magnetic fluctuations. Thus the NPN/PNP are cooled (Tariel/SR/Tiger all have it). Thus the LV coil wire has larger diameter than HV wire.
I will prepare a setup (one month still..)
All i see is that few just got their toroid ferrites, others fail to do simple tests like cosmo so many times suggested, others only negative comment on positive contributing members, others have no clue of electronics, and so on.
Those who have their hotdog toasters and fail. Can you lay open your parameters in your setup ?
What was said about Dollard, regarding fixed magnets, i did not speak of using fixed magnets. We are creating electromagnet here. Is different thing. Also we're not making mechanical moving parts. All is true electromagnetic power generator.
About LV, shown in schematics here... Did anyone analyze it ? Why in both high and low level of the clock signal, one or the other of the bifilar windings is creating flux in same direction ? The schematic here and cosmo's test setup schematic the direction is reversed. Did anyone notice yet ? So, who has a clue what is going on in LV part ?
So far i have not seen the usage of the HV effect to block upper coils ability.
If you're bright, you understand this is technical post to set things clear, not time-waste-chatter.
Shokac
@Catalyst
look may last post.
Can you give me answer? It is the first step towards OU.
forest
Quote from: Shokac on October 16, 2010, 05:41:20 PM
Does anyone know how to switch 220V through the coil, and that everything goes through the inverter 12V. (cca 1A)
Or better yet to ask. How over the 12v power inverter and SR / Kapanadze / Cosmo transformer to get 220V but without any additional excitation?
Scheme?
What do you mean ? Getting 220V from 12V without going through inverter ?
baroutologos
Personally i would not argue anymore if i have not conducted the suggested Cosmo experiment and draw conclusions. (soon)
And here we are. Today i found some time for experimenting with the experiment Cosmo described.
Procedure
I put together 17 (glued) ferrite rings 2000 Permeatability, Soviet type (40mm diam).
I wound on them one common electrical grade wire some 40 turns, and upon it some grade wire another 40 turns or less.
I took one handy transformer and put a 4amp (40w bulb) in series with the LV AC source so as to provide some 3,5 amps of 50 Hz AC current flowing from the top windings.
The bottom winding i connected it via an also handy spark-gap and to the custom made HV source i have composed of a 555 timer oscillator, an Ignition coil and a FWBR.
The particular HV source is pulse adjustably from 250 to 4000 Hz by the 555. In real terms i do not know if this is so or it speeds up by the HF currents interference as i have noticed in many respects of inverters interfering with spark-gaps.
The LV 50 Hz current of 3,5 amps is just too few to create a noticeable attraction to any ferromagnetic object at the end of custom ferrite solenoid. BUT, if i take a strong neo-magnet as Cosmo suggested the magnet tends to act as a magnifying glass, greatly enhancing the sensation of the created magnetic field around the solenoid. (my fingers still buzz)
From my setup and in any respect, i failed to perceive any change in magnetic field's behaviour by the application of the HV via the SG. I made some combinations using a ground, opposing polarities, pulsing the LV winding via a diode (one way wave), still no difference observed.
Any suggestions?
PS: I observed that unconnected to LV transformer, the ferrite solenoid is electrified and small sparks go to my finger. I measured two points of a ferrite rings and DMM shoes it has a small but appreciable conductance
PS2: I put a coil inside the ferrite solenoid.This coil is not couple inductively to the outer coils.
The whole point of ferrite saturation and Coils inductive coupling reminds me Tesla's patent No 433,702.
dllabarre
Nice looking setup as usual!!
So your LV is ~10 volts.
How many volts in your HV?
Thanks
DonL
