0 Members and 291 Guests are viewing this topic.
Shokac
Quote from: exnihiloest on October 22, 2010, 06:00:29 AM
It can be clearly concluded from the patent WO2008103130 that there is HF in the 2 coils:
"Creating a magnetic field around itself with the high frequency regularly received
from the first filter".
HF is confirmed in Kapanadze's video by the low number of turns of the coils, which is incompatible with 50hz. The coils coupling can work only with HF.
Producing HF with a spark gap is easy and not expensive. If HF is 50Hz modulated, then a simple non linear and also not expensive component (diode or saturated ferrite...) is enough to provide 50hz by rectifying the high frequency.
I agree wit you.
Look this site and explanation:
http://ludens.cl/Electron/dcdc/dcdc.html
poynt99
Quote from: sigma16 on October 22, 2010, 12:38:03 AM
If the device that was shown outside in the garden has 50Hz output, then why the need for an inverter and the device in the can between the output and the inverter?
It's possible that the green garden unit was designed only to handle a standard 220V 50 Hz input. That could explain the reason for the inverter at the input.
The "can" is most likely an isolation or step-up/step-down transformer that allows the green unit to run continuously closed-loop with no input source.
.99
sigma16
Regarding the device shown in the garden:
Nanosecond pulse is good if the coil is only excited by the pulse through the spark gap (impact excitation).  In this way the coil will ring at it's own frequency.  There is no capacitor after the gap, and no other coils except output coil, so primary coil could be directly excited by spark gap.
During the initial rise the the impulse, there is no current in the coil, yet something is moving like a current. ;-)
The can in the garden video probably converts the output to DC of 12v.
penno64
Hi all,
I know this is "out there", but I have to ask.
Is it possible, that what THANE is showing us, is what TK and others have stumbled upon.
or am I completely off the radar.
Penno
scratchrobot
Quote from: penno64 on October 22, 2010, 03:07:17 PM
Hi all,
Penno
Here are only speculations about how it should work so maybe? But I think it works different.
Today i played with the Magnetic amplifier with reactance coils. http://sparkbangbuzz.com/mag-amp/mag-amp.htm
When i put transformers in parallel everything works like it should. http://www.youtube.com/watch?v=GWp5NVX9E2Q
But when i put them in series i get hv at the battery side ??? http://www.youtube.com/watch?v=ubiJ_sMt06I
Here i modulate the trigger signal from bat to transformers to see what happens, strange effect. http://www.youtube.com/watch?v=JLGGVtXxNxQ
