0 Members and 114 Guests are viewing this topic.
baroutologos
I disagree. The mechanical version we built was nothing but a coil and a cap. The coil had a variable inductance by way of a rotating core piece. With nothing but a variable inductance you can make big power.
To what exactly are you reffering to? Have you made big power or just speculating ? :)
ps: By the way, can you post links to the papers you are reffering to? it would be a nice read.
LtBolo
Quote from: baroutologos on November 05, 2010, 12:39:02 PM
We built a motor driven device that altered inductance with a rotating core piece. It worked very well. This is not speculation.
The blue trace is current through a 0.5 ohm resistor. The yellow trace is voltage in the resonator. The system peaked out at over 8 amps and 400 vac. We shut it down before it ate itself.
iws1987
@LtBolo
Thanks for sharing this very nice proof of concept experiment.
Just in case Hectors replication of the Ecklin generator are unknown to some, here it is. This is also a parametric excitation machine.
Eric
iws1987
And here are the test data, I had to split over two posts due to size restriction.
Eric
LtBolo
I hadn't seen it. Thanks for the info.
In our build, we saw that the load on the rotor was increasing with the power increase, so it was under unity. I see in this data that they claim the rotor stays unloaded. I will study this to try and understand how it works differently than ours did. It was pretty obvious to me that the big WITTS generator used this principle...our unit sounds exactly like theirs when running...but I wasn't sure how the rotor could be unloaded. This is good info.
After years of goofing with this stuff, I think we are finally on the cusp of making some practical devices. Why this stuff isn't in production alludes me, and makes a very string statement about the reality of suppression and/or greed keeping stuff hidden. We just need to get over the human failures and get something built and out to the world...Lord knows we need it.
