0 Members and 166 Guests are viewing this topic.
forest
Notice one interesting thing - in Don Smith circuit output from priamry coil is negative HV. Is that possible to obtain such from car ignition coil ?
Is there a way to measure the length of wire inside car coil by using a signal generator and a scope ? it is needed to create primary coil length match exactly 1/4 of input wavelength. The rest seems easy.
baroutologos
@ energie,
I have been thought about this. Actually i have developed a thread http://www.energeticforum.com/renewable-energy/5392-ground-based-energy-systems.html
in energeticforum.com about the possibility of extracting energy from earth via resonance.
The point is to be there energy to be extracted, in oscillating current mode of considerable "voltage".
Assuming that eath's telluric currents hum max at 500Khz frequency, then it will be a matter of design in how to tap them effectively.
Unfortunately, we have not any indication that the earth's currents are in this frequency range and are "strong" enough for achieving meaningfull magnification via resonance. (and power extraction consequently)
By the way, it requires some investigation to see it yourself
forest
it's not about telluric currents at all, those are only remnants of real power
because if Earth rotate in own static magnetic field then every metal would have free electrons at high potential=high electric pressure but we would be unable to see them
nievesoliveras
@iwd and @groundloop
Will a 555 timer circuit running the ignition coil work?
Jesus
IWD
yes in sense of creating high tension spikes whicih will discharge from ignition coil to the primary, but you can go with it only to letsay about 100khz or lower, because you need to keep pulses enough long, to create enough large spikes, inductive reactance of primary ignition coil will not let flow more curent for particular(shorter) pulse lenght. And next,...for that frequency is hard to create secondary resonant coil without conecting paraller capacitor. Of course, you can wind a bifilar coil, which can have resonant frequency about 100khz with no problem. But then forget to have wire lenght of 1/4 lambda. And ...these resonant HV transformers seems works best, when use earth capacity more than capacity betwen turns, or classicaly connected capacitor. But that all does not matter, because without capacitor discharge, you will not have needed current on primary. No magneticaly field, and thus that, you will do better, when you directly place a antene, or just some foil around secondary, and feed the secondary only by capacitive coupling. Like this:
http://www.google.cz/url?sa=t&source=web&cd=5&ved=0CD0QFjAE&url=http%3A%2F%2Fwww.overunity.com%2Findex.php%3Faction%3Ddlattach%3Btopic%3D7669.0%3Battach%3D36608&rct=j&q=capacitive%20transformer%20testatika&ei=7bLxTKyICYztOa_HuZsK&usg=AFQjCNGSWqikCoHRIZGRtwYUD0TOJSWz5g&cad=rja
