iceweller
SR's 19 Ferrite toroid Core stack before taping & winding
iceweller
Possible hidden component in series with external (large) coil in TK's "green box" setup as mentioned below:
http://translate.google.com/translate?js=n&prev=_t&hl=en&ie=UTF-8&layout=2&eotf=1&sl=ru&tl=en&u=http%3A%2F%2Fnext-energy.ru%2Fforum%2Findex.php%3Ftopic%3D40.6739
Interesting theory with explanation relating to TK's modus operandi:
http://translate.google.com/translate?hl=en&sl=ru&tl=en&u=http%3A%2F%2Fhalerman.narod.ru%2FTTCG%2FKapanadze.htm
Interesting quote:
Kapanadze reinforced this misconception, adding that:
"I would not be so insolent to say that this is my invention. I found something. Correctly. This (is an) invention of Tesla... Over his invention (I) also worked on his scheme. I just found a *resonance*, which automatically adjusts the resonance between the primary and secondary coil"
And to the question: Where's your response?
"Here (pointing to the "green box"). And the response is held between the primary and secondary windings. This is exactly what is so to speak, at this moment, the secret of the H ... I previously could not reach ... resonance inside. This is exactly what is so to speak, at the moment, a secret. "
   He found a "resonance between primary and secondary" and there lies the secret. There it is, a resulting (freq primary / freq secondary) resonating frequency that somehow taps into the "ambient".
   Modus operandi of TK's device based on paper which I think is possibly the closest theory proposed until now:
To implement the scheme with the passive receiver TT needs the following elements:
1.       Source of high potential ("transmitter") (=HV HF & SG)
2.       Passive CT ("receiver") that takes the high-voltage potential of the "transmitter" (COUPLED COIL)
3.       Load in the circuit inductor passive TT (= OUTPUT)
4.       Scheme agreement "transmitter"   Ð¸ «приемника» and "receiver" (= RESONANCE Primary/Secondary freq. - the key)
   Point (2) with point (4) create the "ambient receiver loop" or secondary source which is "dumped" on point (3).
   TK's "secret" in his own words is this resulting resonance "IN" the coil.
  Magic's points:
1. Kapanadze began with a mechanical chopper spark (from a Tesla Electrical Circuit Controller, Patents US â,,–: 609245, 609246, 609247, 609248, 609249, 609251, 611719, 613735). See the first movie about Kapanadze.
2. Next he worked on electronic circuit replaces mechanical chopper spark. This device can be called - an electronic controller circuit breaker spark. "Green box". You can do without the super transistors, which he did. "... Something that I found" (his words from the movie). Tesla had to periodically adjust its mechanical controller. So he decided to transfer energy from one place, where there will be attendants. The device was not an automatic, required constant adjustment. In the patent Tesla Serial No. 598.552 thrice repeated word synchronism.
The electronic controller makes it self up phase.
Saying: "The resonance of both within and between primary and secondary windings, Tariel had in mind in sync with the resonant frequency. Try to explain it to someone and you get: "The resonance to resonance.
3. Grounding Tariel used to lower the frequency of the serial circuit.
The apparatus 7 kW ground anymore. Coil of larger diameter and length. Inductance above. Frequency is acceptable.
4. The frequency of the secondary coil is not 50 Hz. Who is a "duck-joke" abandoned? Others speak of beatings high frequency (MHz or more). The frequency of the one that came out at a given wound inductance and capacitance of the earth. And under this frequency (which varies by temperature, humidity, vibration, and other things) an electronic controller adapts to the "green box". A tesla adjusts its Mechanical Electrical Circuit Controller.
5. The output of the inverter is placed, which produces an alternating current with the standard frequency and voltage. Which is reflected in the patent Tariel WO2008103130A1 9.-Current Amplifier - current amplifier (the third coil); 10.-Second filter, 11 - Frequency Adjuster, 1912 - Stabilizer (phase). Paragraphs 10 ... 12 - this is an inverter.
6. Tariel repeated Tesla one to one. About it himself and said: "I would not be insolent to say that it came up with himself ...." The mechanical controller has electronic and everything.
http://tinyurl.com/23vk3vy
DimaWari
@iceweller
Maybe your right... I wonder why TK said his device can be use in airplane? And why code name SR193 resemble with SR90..  Why those two men in the picture of 100Kw Kapanadze Gen are already dead.. SR himself said he got sick for 2 days while doing experiment.. And if you look at TK patent He was not after HV but High frequency generation.. He is cooking something and thats what Im looking for..
I guess we need to dig some more my friend..
exnihiloest
Quote from: iceweller on December 13, 2010, 07:25:38 PM
I agree but it is not enough. In order a LC circuit to resonate, the two ends of the coil have to be connected to electrodes which constitute the capacitor C. For example in a tesla coil (http://fr.wikipedia.org/wiki/Fichier:Teslacirc1.png), there is the ground, the coil and the terminal upper electrode having its own capacitance (which thus constitutes a capacitor whose the second electrode is the ground, looping the circuit).
In Kapanadze's device there is only one ground connection, so we don't see how it works. Or should we account for the capacitance of the whole stuff relative to the ground? It is unlikely because in this case the resonance would be very sensitive to the position.
