0 Members and 1854 Guests are viewing this topic.
xenomorphlabs
@the_big_m_in_ok: This junction must be connected, there is no way to get charge on the cap otherwise from the D.C. plus terminal of the rectifier.
@Bolt: I sure will also get a NST ;) For a start i just use the ignition coil.
Quote from: bolt on July 19, 2009, 08:54:20 AM
The transistors dont see this voltage they only see the PD difference despite they are floating above ground at 30,000 volts. Bird on HV grid wire :)
Please help me understand his inverter idea.
In D. Smith´s (more conceptional than detailed) diagram he has the emitters floating at 30 kV (like the bird), but as soon as the base gets triggered the collector emitter WILL SEE 30 kV and the base emitter voltage is also -30 kV constantly (Maybe a high ohm base resistor can fix that issue as depicted in the diagram).
Please bare with me, if my limited knowledge of transistor operation might prevent me from understanding how this is meant to operate by Smith.
I also ask myself why he connected the emitters to the higher potential than the bases in the case of NPN - transistors, because in theory the NPN would never fulfill the 0.6V Base-Emitter potential difference to actually open that way.
hartiberlin
Quote from: HeairBear on July 19, 2009, 01:14:55 AM
I can't belive it, but, I think we have a double winner here. I'm gonna go out on a limb here and make a rather bold statement. I had just finished watching a video posted recently by Tinselkoala showing some rather strange findings. For those of you not familiar with Anslie's work and TK's radical debunking skills, TK has had a heck of a time replicating this experiment. After seeing this video, I believe TK has accidentliy found how Tariel ran his device after disconnection from the power source. Here is the link to the video...
http://www.youtube.com/watch?v=jZzzMVx6rPY
Crazy! Just plain crazy!
Hmm,
seems TinselKoala just really stumbled onto the Kapanadze effect ?
I will email him, that he should further investigate this ground
loop oscillation effect.
Many thanks for bringing this up.
Regards, Stefan.
0c
Quote from: hartiberlin on July 19, 2009, 12:05:36 PM
Hmm,
Regards, Stefan.
More likely, TK stumbled on an unconventional way to extract power from the mains.  ;)
hartiberlin
Hi xenomorphlabs,
it is a bridge oscillator,
like a Multivibrator.
It just transforms the DC to AC
via transformer and current pulses from the 2 transistors.
Check out other 12 Volts DC to 230 Volts AC inverter
circuits on the net to compare them.
Regards, Stefan.
hartiberlin
P.S. xenomorphlabs
in your circuit is an error,
where it say 0V must be the the DC positive
voltage, otherwise, there would be no current flow
through the transistors to ground , when a transistor is conducting.
