0 Members and 204 Guests are viewing this topic.
iceweller
Postulate: Energy in = (Energy out - Losses)
Universal Source of Energy = Universal Ambient (virtually unlimited/continuously reconverted)
Conventional thinking:
Local E Input = Local E out - Losses (conversion)
Bigger Picture:
Local TRIGGER Energy Input = Abundant "hidden" source of Energy (Ambient/radiant/universal) - Local trigger E losses (resonance maintenance for ex.)
     This "access" appears to happen with 2 simultaneous effects in this case as stated by SR, one is the "conditioning" HV pulse through SG around the ferrite core and the other is the modulation coil which at the right moment or phase of this effect dumps the extra field onto the load coil that the ferrite "extracts" from the ambient.
    Hints from SR:
    - KT's green box device is somewhat misleading. The Turkish 100kW setup video though show's a good 80% of the concept (look at the Spark Gaps).
    - Parametric Resonance is not involved!
    - madsat's video contains an important element (http://www.youtube.com/user/madsatbg)
forest
Doppler effect ?
Experiment : if we have two separate devices generating opposite sound and running at the same speed (being in the same frame reference) do we hear anything ? No.
When one device is slowdown for a peak moment and then return to the same speed we see Doppler effect and energy is visible and usable. Above ambient.
Earth system is electro-magnetic surely. Our device is EM too. What is our mistake that we can't do the same as Tesla - make an oscillator running itself for years once started ? Is our mistake "the closed path rule" ?
LtBolo
Quote from: exnihiloest on December 21, 2010, 03:43:13 AM
There is no real difference...
My theory may be completely wrong for a great many very good reasons, but none of the answers given back to me seem to be addressing the real point I am trying to make. The earth appears to be a reservoir of charge. It either gives it up in lightning, or takes it in, but the fact that huge amounts of charge are flowing to or from the earth during the abundant number of lightning strike every day suggests very strongly it contains a large amount of free charge.
So if the earth is at an absolute non-zero charge state, then how do we define zero? If zero is something different than the earth, will the earth flow to zero? If the earth flows to zero, will it's behavior be similar to two caps leveling out?
All of the answers keep speaking in terms of charge separation and relative charge. I'm not talking about relative charge...I'm talking about absolute charge. I am reasonably confident that the capacitor as a charge separating 2 pole device doesn't offer any free energy, but if the earth is a virtually infinite source of free charge, then can we use capacitive behaviors to coerce it into giving us some of what it has? Kapanadze's and SR's devices both seemed to need a good ground...I take that as a clue.
forest
LtBolo
I also think that Earth contains a lot of charge but the key question for me is not how it can be made usable (though it is important) but why that charge is there ?
If as I suppose it is by electric current from space which also is a source for gravity and magnetic shield then probably not only ground contains free electrons but also any metal (recall how Tesla taol about Earth as a polished metallic ball in space).
For me indirectly Kapanadze proved my concept my talking about 3 phase device not needing ground connection. Also other his video when as ground he used large metal construction of building not directly grounded in real ground indicate that this idea may be correct.
If you watched Tiger replication videos you probably saw that he disconnected real ground and device still worked more or less undisturbed. He has shown that the ground wire in his setup works like antenna capturing "something" which effectively raised efficiency of the circuit.
LtBolo
Quote from: forest on December 21, 2010, 12:10:11 PM
Super question.
So you think the excess charge may be more or less steady state in anything big enough to catch it? That would be a wonderful thing, if true. That would suggest that lightning isn't so much the result of accumulated charge as much as perhaps an imbalance in the ground state due to variable media density or something like that.
Haven't seen Tiger's vids, just saw the schematic Did he ever get anything stable and measurably OU? Gotta link?
