0 Members and 105 Guests are viewing this topic.
iceweller
Quote from: DimaWari on December 21, 2010, 10:29:18 PM
@forest
Hop on my friend were on the same boat... The way I see it.. The trick is how you burn those ferrite rings, align those particles and capture, then store it and then discharge.. at least we have a strong theory around here.. now there is a material that is more suitable for burning.. The same material used by tesla in his car..
@ Dima - yes, SR does this the same way (at least he says so):
   1) Align/prepare magnetic domains in ferrite with HV pulse
   2) the domains now capture the "ambient" field but it cannot do any "work" yet
   3) modulate/oscillate/move this field with the bifilar coil (at the right moment/phase)
   4) now the oscillating field can do work and is picked up by output coil
   Question: is the position of the SG respect to the core relevant? The SG emits a pretty broad RF spectrum - could the position (and not just gap/voltage or frequency of discharges) influence the capture effect?
DimaWari
@Iceweller
Perhaps my friend, Sr sparkgap was perpendicular to his coil. Even in 100kw and the first video of TK. I prefer to use other material for my experiment because its hard to find ferrite rings here in the Philippines, and I will apply the same theory...
wattsup
Quote from: iceweller on December 22, 2010, 05:15:46 AM
That is a good question. Proximity to a high voltage low amperage fixed frequency spark gap could produce some output into any properly tuned sympathetic pick-up coil but I do not think this will add in any substantial level to light the bulbs. But it could be used to feedback a signal to the transistor gates.
The TK video already showed in the second demo with the radiator ground that the ground wire does not have to pass through the transformer core for the device to function. So what if you placed the spark gap inside the core opening instead??? Maybe to reset the core or create more havoc. lol
Added:
Regarding the ferrite core or toroidal core, is there any major consensus on core material type or brand name and model number. I want to order some for for 2011.
iceweller
Quote from: wattsup on December 22, 2010, 08:24:14 AM
   Actually the black ground wire still passes through the coil in the second ground connection in TK's green box footage: they simply disconnect the thick black wire from the faucet and connect it to the white wire coming from the buried radiator, but the other end of the black wire is still routed through the coil. Look at 25.00 on the complete footage and you will see they are testing the potential difference between the usual black ground wire and the new white ground which TK is holding in his hand connected to the black one. A second SG inside the core is also a possibility.
   @ Dima - in all the footages SGs are perpendicular to the bifilar zone of the coil and apparently in the nearfield. The transistor wires in SR's footage are long and sloppy - maybe just a coincidence. They are normal bipolar so their input impedance is not so high and possibly are unaffected by this noise.
energia9
build your ideas friends, that is your best help,  writing is nonsense until prooved by the human sight,  hey i dont mean to argue with you guys,  i would like to PUSH you to experiment so we can all help eachother with real results,
i wish you guys fun and excitement with the  experimentation!
take care
Energia
