0 Members and 235 Guests are viewing this topic.
quarktoo
Quote from: khabe on January 20, 2011, 06:50:54 PM
wattsup,
This is sure, I cannot be bothered to scrabble up to attic of my workshop - there under lot of junk I have exact the same Soviet rectifiers, even heat sink looks the same, my diodes are green, somewhere I have thyristors as well. Found one similar item from ebay, this is bit younger, newer type of,
http://cgi.ebay.com/Soviet-THYRISTOR-T15-160-14-T15-1400V-160A-NEW-/350406510819?pt=LH_DefaultDomain_0&hash=item5195db08e3
cheers,
khabe
So you are claiming that the Kapanzi device uses four diodes in parallel? For what?
Now look at how the Gray device is wired. They are connected together at the top. Not saying you are wrong, I am just saying I don't understand how or why that would be in the circuit that way.
They do, as you claim look very close, but they are not what you show in the ebay photo. Look at how they are taller and missing the black insulation. maybe newer as you say but still does not make sense.
quarktoo
Here is what would make sense. In the 30KW demonstration you saw four tesla coils arcing and so you need to switch the primary of those four phases or Tesla coils. An ignitron would be a good way to do that rather than a spark gap which makes noise and wears out.
Since the devices look almost the same and since I feel the devices work using the same principle which people are not noticing yet but has been used many times in the past, all I am saying is have a close look and think about what you see.
Why do you see tubes and hoses on some of these devices? Think about that.
khabe
when all is said and done ... found from Russian sites few photos about these diodes  ::)
cheers,
khabe
quarktoo
O.K. Kahabe, so where in the circuit are diodes used?
We know that the primary of the transformer has to be switched. So an ignitron or a thyristor would both serve that purpose but a diode? Not helpful there.
The device puts out AC, not DC.
All I am suggesting people do is think about what you are looking at instead of assume or believe.
Next, look at the many different devices that use high voltage to trigger something and what is that high voltage being used for? In other words, how do we use high voltage to make more electricity?
The answer is simple if you compare many different free energy devices that are similar. You will see a pattern and once you learn the trick they use... You will learn how many devices worked by figuring out just one technique. There are many techniques.
Someone stated a few pages back that he didn't care about specifics, he wanted to know the underlying principle and from that he could invent his own. He was wise and intelligent.
Photo analysis is most helpful. Blow up the photos and look at every detail and ask yourself questions. Usually the key to learning the answer is asking yourself the right questions.
Monkey see monkey do isn't going to get you there. You are going to have to put the pieces together and when you look at the posts I have made, I told you 99% of the answer. I can think of probably five devices that all used this trick going back to 1920.
Think about it.
core
Quote from: quarktoo on January 20, 2011, 08:55:11 PM
The answer is simple.
Think about it.
Here we go again  :-[
  Before you embarrass yourself anymore you should be aware we have already been down this road with those same words as recently as Oct. of 2010.
   If you have something to share, other then one liners, then I am sure members such as LtBolo, dllabarre, stivip, myself and others will gladly give you the floor and you would have our undivided attention.
  Every forum has that group of people who claim to know but will not tell. Your words are simple not original and I am sure they have the other legitimate members here rolling there eyes.  ::)
  So if you have something to say then I, and others, RESPECTFULLY give you the floor. If you are interested in nonsense and petty riddles please find another thread.
Respectfully,
Core
