0 Members and 173 Guests are viewing this topic.
quarktoo
Quote from: forest on January 29, 2011, 02:17:02 PM
There is something interesting in Tesla patents related to wireless.
For example :
"A is a coil, generally of many turns and of a very large diameter,
wound in spiral form either about a magnetic core or not, as may be
desired."
I'm not sure what to think about this.  ???
Don't think about it Forest, it's a pancake coil.
The likelihood that you could replicate something from a patent is usually next to zero.
Patents are to claim intellectual property. Left intentionally vague, they allow the inventor the possibility to claim more than what is there through a lawsuit. It is a legal document, not an engineering guide.
Shokac
Quote from: penno64 on January 29, 2011, 02:46:20 PM
@choose and Shockac
Thanks for the info guys.
Shockac, did you also use the spiral type winding ?
Reminds me of RODIN
Regards, Penno
No, I use classic winding, and use winding from first setup of SR.
My next try is like setup of Frank Hubbard. Center is big coil with ferrite, and secondary is 8 smaller coil with small ferrite core. Center will be transmiter and secondary will be receiver. (8 receivers).
Shokac
Quote from: leo48 on January 29, 2011, 07:58:43 AM
I was thinking that perhaps Leedskalnin had built something similar
http://img705.imageshack.us/img705/6236/bottiglia.jpg
Leo48
I saw this staff, but i don't now why is in the button on this bottle?
What Leedskalnin put in the bottle?
If you look aquarium setup of Kapandze, you will find coil like bottle.
forest
Quote from: quarktoo on January 29, 2011, 03:09:20 PM
Interesting.... are you trying to discourage me from building it ? Huh !?
My point is : seems that for Tesla it doesn't matter if pancake coil have air of magnetic core. The ,method works the same.
I would guess that Tesla at least checked it. There is also small clue that he may used magnetic cores more frequently.
From the same patent.
http://www.teslauniverse.com/nikola-tesla-patents-649,621-transmission-of-energy
"The length of the thin wire coil in each transformer should be approximately one-quarter of the wave length of the electric disturbance in the circuit, this estimate being based on the velocity of propagation of the disturbance through the coil itself and the circuit with which it is designed to be used. By way of illustration, if the rate at which the current traverses the circuit including the coil be one hundred and eighty-five thousand miles per second then a frequency of nine hundred and twenty-five per second would maintain nine hundred and twenty-five stationary waves in a circuit one hundred and eighty-five thousand miles long and each wave would be two hundred miles in length.
For such a low frequency, which would be resorted to only when it is indispensable for the operation of motors of the ordinary kind under the conditions above assumed, I would use a secondary of fifty miles in length. By such an adjustment or proportioning of the length of wire in the secondary coil or coils the points of highest potential are made to coincide with the elevated terminals D D', and it should be understood that whatever length be given to the wires this requirement should be complied with in order to obtain the best results."
925Hz is within the range of soft iron core.Rather then air core, of course I'm not sure.
Ghost_Rider
