0 Members and 152 Guests are viewing this topic.
core
Quote from: dllabarre on February 06, 2011, 08:57:33 AM
I for one don't post the results of all my experiments.
Usually posting results brings out pages and pages of crap from "arm chair experimenters" "dis-informationalists" "derailers" and it's not worth it.
What are your results from Otto's circuit?
As for Stan Meyers.  He was having trouble keeping his circuit stable because as H2O was being split into H and O it left behind a higher concentration of all the other minerals in the water thus changing the capacity of the water fuel cell.  As the capacity changed he lost resonance.  That's one of the reasons why Stan developed the injectors.
DonL
I hear you Don. I have been working on a dis-charger for the longest time. It's truly disruptive discharge but in a way nobody here is doing it. The problem I have is that my components are not rated to handle the power. When I do get a spark the gap points 'stick' together from the power. I need to order some hi-power diodes that can handle greater then 400 volts at 20 amps or so. Maybe that will prevent the premature failure of them. Also a hi power switching Mosfet would help also.
  When I get it down pat I will share it. I do have to say, when it works it provides a powerful hi amp white hot spark. Right now I am switching at 1Khz may have to raise this higher. Also I'm trying to hit 600 volts or greater.
Respectfully,
Core
wattsup
@all
Regarding the coils wrapped over capacitors, I took a 150,000mf by 200vdc capacitor that is 3" diameter by 4" high and wound a single strand 10awg coated wire of 25 turns around the capacitor. I pulsed the coil with my HP frequency generator at 16vdc at milliamps and at 15.2mHz there is definitive coupling being imparted to the capacitor that then lights up my 5vdc LED bank via a dioded tank capacitor that holds at 5.36 vdc. I did some more tests on this putting the capacitor in vertical to see any differences did not show any major changes in coupling. I think at best this could be used as a step down transformer if the coils were being pulsed with high voltage.
I remember 3-4 weeks ago when I noticed that those coils could be wrapped over capacitors, I tried this but the cap was a non-polarized black plastic cased capacitor and I did not see any noticeable effect. But this DC capacitor is different. I am actually stunned that I am getting coupling like I would get with so many of my coil to coil systems.
The best part of this is that there should be no Lenz law involved in such coil to capacitor transfers. I am sure at higher voltages the transfer will be rather generous and what I am thinking is that TK used these to draw off power back to the system. The coils, being rather thick awg would offer next to no resistance to a pulsed feed line. While the energy is being pulsed through the coils, the capacitors draw off some return power without creating any major added resistance to the feed line. This is rather a major thing here that just opened some new avenues for playing around. Just this new way is worth all the hassle of discovery.
wattsup
quarktoo
It is interesting when you do the math on what Saint Buzz just wrote.
The frequency for ferro nuclear magnetic resonance is ~21.5 MHZ with is a wavelength of:
13.953488372093025 meters
The copper wire/tube running through the center of the coil produces a 1/4 wavelength shift for a length in meters of:
3.4883720930232562 meters
divided by 3.4883720930232562 meters
= 4.0000000000000000573333333333333
The four phases or 90 degrees of a sine wave to infinity or very close anyway.
Saint Buzz told me you need the spark gap to produce that cavitation to launch the electrons off the highest orbit. Timing is everything.
So if he was using 470 uf of capacitance, the inductance would be:
1.1658976099789422e-7 uh
The frequency would be ~21.5 mhz
and the impedance would be 0.000015750026072109068 ohm
That sounds quite plausible for the coil shown in his video.
The atomic rotational differences between ferrite and soft iron would explain why they are not seeing the heating problem normally associated with this type of a device or method.
quarktoo
In this photo you can clearly see the ferrite ring cores:
core
Quote from: TheBuzz on February 06, 2011, 03:48:57 PM
[ Insert many thunder claps and much lightning ]
Saint Buzz hath come down from the heavens to help thy mortal souls and thou shalt listen to thy words of wisdom.
TheBuzz hath filched a schematic of the SR193 device for thy weary minds to ponder. Thou will notice a RC RESONANT inductor capacitor section which produces the mesomeric (resonance) effect upon the electron orbital planes of the FE56 atoms. The reduction from FE56 to FE54 yields two electrons for which you may keep to light your way.
Next you see a "modulator" coil. The combination of these two frequencies is called heterodyne and the result are frequency sidebands and harmonics which reach far into the spectrum in both directions.
This is what Stan Meyer referred to as "electron bounce phenomena". Saint Buzz and his chosen "Quarktoo The Holy One" hath preached this upon deaf ears for years. Let those that have eyes that see and ears that hear, find their way to the free energy heaven through mass to atomic energy conversion. (E=MC2) The souls of all others, not so much...
The acceleration which is [ the word ] is produced by the cavitation of the particles through shorting the electron to the proton as the electron oscillates from its highest to lowest orbits and subsequent energy states. As the negative particles build up, thy needs to have an earthly ground to send them to or the entire device could reach out and bite you with death.
The radiation shielding requirement is necessary (ALPHA, BETA AND GAMMA RADIATION EMISSION) or you will be joining Saint Buzz in the heavens once you die of cancer. Heed thy warning for this device is not for the feeble of mind such as Grumpy and RAMSET THE DAMMED!
Ramset THE DAMMED where is the star you hath stolen from Saint Buzz! I shall roast your even toed cloven feet and serve you to lesser beings if it is not returned! I want my seventh star back!
Saint Buzz shall now ascend back to the heavens to bask under the light that shines from Thine many golden overunity.com stars and elite forum status.
That wiring diagram has been around for a long time and has been dismissed by the Russians. Please stop posting diagrams you are finding on 'Google search' as an 'ah ha' moment. Please read the last 300 pages before posting. This is old.
Respectfully,
Core
