0 Members and 491 Guests are viewing this topic.
Paul-R
Quote from: bolt on July 20, 2009, 04:59:36 PM
This is one of the oldest and easiest systems of Don Smiths. It uses casimer effect to change NST 8kv at 50mA into a large bank of caps selected so the CRL = C =uF feed into trafo primary which can be any big regular mains trafo you have laying around while its input L inductance selected by timing resistor R  to match required 50/60 Hz.
The grounds are ONE common ground this is NOT Kapanadze system. T
Page 54, message 531:
Would someone be wiling to turn this drawing into a circuit diagram that a prototype could be built from?
nievesoliveras
@all
There is this guy at http://instructables.com that made a tesla coil using the same construction of the centered primary coil of Don smith and Kapanadze here:
http://www.instructables.com/id/Tabletop-Tesla-Coil/
I think that the construction he used could be a model for what we need. He even posted a video of it working.
Jesus
flathunter
@Yucca
Thanks for clearing that up for me!  Very clear and concise post!
I really appreciate all the help, as this is my first coil. I've just made a receiver coil of about 100 turns, and placed it about half a metre away from my secondary....ive connected the ends of the coil to 3 neon lamps, and it works a treat!  My first wireless transfer, with no sniffer wire :)  I've tried the same thing with just a capacitor plate and ground wire, to much the same effect.  I'll try the doorknob capacitor now......
Like you say....a whole lot more fun than telly!
xenomorphlabs
Quote from: Paul-R on July 21, 2009, 07:59:36 AM
I could do it and Bolt could do it too. Maybe the patent he has explains more.
There is just not enough data for you to make a prototype.
No info available on the NST, except that it really might be a small one according to some people that look frantically for one hehe. You would need a very similar model for this to work.
No info on the output transformer dimensions.
It is mentioned twice that the working level is 460 Volt (caps and varistor) which surprises me and seems too low.
If you still want the diagram just let it be known.
bolt
This is a universal setup you tweak the values to suit what you have available but the circuit remains the same. Having a circuit with listed parts means nothing as then people learn nothing then complain they can't find a particularly value.
Look if i give a RatShack parts list for prototype system that calls for an NST model 4674636 @ 110 volt 30 mA 9kv o/p then people outside of the US will say "hey i cant find that part so i cant make it."
OR " will a 240 volt model 385747 from china work? "
YES you donuts its about learning to work with the parts you have in your country!! This circuit will work with almost any mains transformer the bigger the better with caps you find anywhere that handle the working voltage and an NST you can buy in any country even if you have to mail order it.
Quote from: xenomorphlabs on July 21, 2009, 10:47:25 AM
