0 Members and 211 Guests are viewing this topic.
pix
@Herger
Concerning your thinking about accelerating/decelerating electrons.A heat pump analogy is interesting. In heat pump areas where refrigerant expands and condenses are separated-heat energy is "pumped" and large air volume of low temperature  is converted to smaller volume but high temperature  air with the help of electrical energy used in compressor plus accesories( fan,control circuit).In the conversion process we GAIN energy, typically COP is 2-5 depending from system. By use of refrigerant media properties we utilise a very basic physical law of entrophy- when refrigerant changes its phase state from more organised (liquid) to less organised(gas) on the expansion orifice- it sucks energy from the surroundings.When refrigerant is changing state from less organised(gas) to more organised(liquid)- by help of compressor it gives off this previously sucked energy to the heated room.So by use 1 unit of electrical energy we catch a few units of  thermal energy from surrounding- it is OVERUNITY. Similar could be for electrons-there is difference when electron is slow and when electron is ballistic.The difference is mass.When electron is bound in conductor lattice it has "stationary" mass, when we accelerate electron- it has smaller mass.So there is obviously energy exchange with surrounding- similiar like refrigerant.Electrons exchange energy with the space when accelerating/decelerating, refrigerant when state phase change expanding/condensing .
Tesla refered to Linde air liquification process.He was referring to the clever setup that Linde utilised, a heat exchangers where a small part of already liquified gas was used to cool incoming gas more in cascading way.Expansion of small portion of gas was cooling larger amount of gas-again phase change gain was utilised.
I was always wondering it similiar phenomena occurs with electrons when they change speed, do exsist a energy exchange with the surrounding space during that speed change?If yes,maybe we should separate areas of aceleration and deceleration in some way?
Regards,
pix
TEKTRON
Near a weak has passed. I have worms and Trojans in my sys. I have not received EM
notification for days from OU. So I think i can get this out now, WTF is Item (9) in the TK Patent?
I do believe this is where we need to look.
exnihiloest
Quote from: scratchrobot on February 11, 2011, 11:57:45 AM
Thanks for the link, very interesting. I did not know it's also a phenomenon in radio frequency (RF)
I strongly believe that this must be the effect we are after, I don't know if it only happens in a vacuum?
Multipactor effect works only in vacuum. Sparks in air and ionisation would destroyed the effect. Where would there be a vacuum in Kapanadze's device?
quarktoo
Quote from: TEKTRON on February 12, 2011, 05:14:54 AM
Me  too! That is how you know some good info. was released in this thread.  If you haven't figured it out by now, most if not all of these FE web  sites are all about intel gathering. You are not doing anything  important if you are not on the no fly list, having your computer hacked  by a-holes or on a list over at the pentagon.
Just share info but do not prove anything with photos. Drives the spooks crazy!
Shout out to Grumpy / Herger.
Note  how Herger always acts like he knows something but never fills in the  blanks? He is baiting you into spilling what you know and where you are  in your learning process. The Grumpy demeanor is a psychological  technique designed to create transfer of authority. It only works  retards and children. Shout out to Mag!
You can always start your  own FE website and ban those that are suspect. You will find that is  90% of them. Best to work with friends and relatives offline and if you  plan to file a patent on something, you better have a NDA from every  supplier and anyone you talk to. Best to just go open source and share  with friends.
For me, I just don't like being spied on so I come here to learn, share and troll spooks. It's my hobby.  ;D
quarktoo
Quote from: exnihiloest on February 12, 2011, 06:14:32 AM
There wouldn't. It's an accelerator coil. The whole multipacitor thing was the usual smoke and mirrors from the spooks.
