0 Members and 39 Guests are viewing this topic.
core
Quote from: stivep on February 12, 2011, 05:25:56 PM
No we all know  what country I have had in mind.God bless Armenia
Wesley
I have a good idea of what country. Maybe it's the big one where 85% of there GDP evolves around energy exports.
Respectfully,
Core
core
Quote from: leo48 on February 12, 2011, 03:18:17 PM
We are almost 380 pages and still groping in the dark .....
Leo48
Nonsense we are finally talking about energy transfer in the natural ambient.
Respectfully,
Core
LtBolo
Quote from: core on February 12, 2011, 05:32:41 PM
I have to respectfully disagree with you. The phrase 'At low ambient pressure' is a bit ambiguous. I can only assume you mean sea level or 29.96 inches of mercury. To follow it up with 'the default state of the refrigerant is gas' states you are simply talking about a particular type of refrigerant known as 'High pressure refrigerants' and excluding 'Low pressure refrigerants'. High pressure refrigerants require a positive displacement pump (compressor) to create the energy transfer. A good example of a compressor-less system is an 'Absorber' a water or ammonia based system.
  In a refrigerant, or heating system some form of pump is used to 'keep the process going'. It must be clearly understood that the pump 'enhances' the operation and 'is not' a requirement.
As an example. In a dry room a glass of water is set on a table with its starting water level marked. After a period of time you notice the water level has dropped significantly. Where did the water go? The water was evaporated into the air due to the simple fact that the water was at a higher energy level then the air. Both the air and the water are subjected to the same atmospheric pressure, sea level in this example. BUT since the water was contained more energy then the air it was at a slightly higher pressure then the air. The evaporation and condensing process is natures way of equalizing this pressure differential. The opposite is true also. If a dry material, or one who's moisture measured in Grains is less then the air's, will absorb energy from the air. The absorption rate will continue until nature reaches an equilibrium. If I remove moisture periodically from my 'so called' dry material I will keep an energy sink going between my 'Dry material' and the atmosphere forever.
  In closing my theories and LtBolo's theories are not to far apart. The BIG difference is that I believe that the ambient, and its electrons and ions, are already at an 'accelerated' state and 'deceleration' is just needed to obtain energy. LtBolo, I believe, states that an electron must be accelerated first then decelerated to obtain energy.
As stated before great discussion.
Respectfully,
Core
I won't get into a debate about refrigeration systems. It doesn't really matter and doesn't change my point that you can mechanically induce a phase change for less energy than the phase change will yield/absorb. The role that ambient pressure plays is simply a function of your default state and starting point. Evaporation, dew point, and such just further complicates the discussion and isn't really relevant to my point.
Feel free to try and approach extraction of electrical energy from the ambient state, but you will be alone. None of the devices that are purported to work start with stationary electrons, and while electrons may be spinning like crazy in place, the drift velocities are functionally zero. The use of caps, spark gaps, and fast transients is almost universally about making them go fast. Why? I think my theory answers that nicely.
Again, how does an X-ray tube work, and at what point does a similar condition exist in a resonant or pulsed transient system?
quarktoo
Quote from: core on February 12, 2011, 05:43:51 PM
Respectfully,
Core
The accelerated loop is quite obvious  but hey, I'll make a red line for the really smart or humor challenged  people. Compression / decompression "is but the illusion". Electrons get  flung off he coil through centrifugal force and that is how it digs  Tesla's well of lower energy. Use silver wire like Edwin Gray for best  results.
Looks like Kapanadzi even used some silver or tin  plating on that tubular coil of his. It is an accelerator coil and  anybody that can't see that or would try and obfuscate that simple fact  should be placed on ignore or bitch slapped.
ramset
Quarktoo
Quote:
Ramset you slut!
Did Mr. perfect paragraph Bolo build one of these? Please stand and join with me in singing the US national anthem.
The Methernitha device is so similar it is worth pointing out that they mechanically switched rather than attempt transistors. According to Paul Potter's description, there were ring magnets that were air gapped.
http://www.grigiotorino.it/progettomeg/testatika.htm
Here is a short article by someone thinking about how compression/decompression by moving the capacitor plates away from each which increases voltage. That increases tension which increases acceleration. That takes work - breath in.
http://freenrg.info/Methernitha/About_Testatika.html
In the proper configuration, I could see how increasing or decreasing the gap between ferrites could increase or decrease capacity which could breath in or out energy from the ambient. The spark gap just makes sneeze. How's that for think-y?
Shout out to the new "chosen one bringer of light to humanity" LtBolo - interesting concept.
I could have used shrink tube and even had the appropriate colors on the shelf but wanted to keep it real, man. Still working on the nose cone section.
Note how I am increasing mass as I move toward ground. Final stage will be large litz wire. Thinking Adrian Krone and negative resistance. (negistor and multipaths).
HHMMmmmm..........
LT has much wisdom and experience in these matters!
An Absolute pleasure to read his thoughts on this ! as well as yours and others here.
I see your build is already at full salute!!I sure hope you get the goods here!
This whole thing is actually getting very exciting!
So much is making sense!
One of you fellows is going to get this,I hope you have a Detector in place for the full spectrum of possibilities here.
Tesla would not have been aware of all these things.
Chet
PS
Quarktoo, whats that Mylar looking thing behind your "Patriotic Phallus of power"??
Thanks Grandma
