0 Members and 138 Guests are viewing this topic.
core
Quote from: Magluvin on February 18, 2011, 08:17:08 PM
Hey Core
I have also.  And it is very similar to the Tesla Pat   Igniter For Gasoline Engines.
It uses a large inductance , as you did, to charge a cap and then discharge the cap into a primary.
Virtually the same circuit. The circuit is genius as to having 1 switch that does 2 functions. Allows the charging of the cap And the discharge to the primary.  Tesla says that it is more efficient this way compared to driving the primary directly as seen in modern ignition systems. This may be interpreted as OU, but it just may be more eff.  Im still working on these things.
http://www.youtube.com/watch?v=uwWhaEPygp8
Mags
Yep thats where I got the setup from.
Respectfully,
Core
core
 I built a small ozone generator, see pick below, for my 'sewer' pipe coil. Was just playing with different concepts needless to say it was as exciting as watching grass grow. I did some research on ozone because I also have heard the stories regarding Tesla ozone generator being linked to OU. I'm getting a different feeling of OU and free energy. I think Im taking the 'Free' part to literal.
Ozone is a diamagnetic gas, oxygen paramagnetic. I began to wonder if ozone was being used as some type of shield on a coil. A vertical coil would benefit from this as ozone is heavier then air. With a generator mounted on top ozone could quickly fill a tube and create a shield. Now, I have mentioned 'shield' twice and for a good reason. I believe we are on a wild goose chase. The best way to keep something 'simple' a secret, is to make it sound 'Larger then Life'.
  In an effort to keep this post short I'll stop here. The next post will deal with how simple this device 'may' be.
Respectfully,
Core
Small Ozone.
_____________
LtBolo
Quote from: Pirate88179 on February 18, 2011, 08:03:35 PM
Forgive my ignorance but don't electrons always move at the speed of light?
A lot of confusion there. To the other posters responses I would just add that the electron volt (eV) is the fundamental measurement of energy in the quantum world. It is the kinetic energy of an electron after being accelerated in a field of 1 volt. Wave energies are described in terms of eV. X-rays start at 124eV and go up.
No, electrons can definitely be accelerated, and interesting things happen when they are.
Magluvin
;]   Im with ya there.  We might be seeing way more than what may be needed. Green box, 2 spark gaps, x no. of coils.   But then I also considered the control part of it. It could be that simple is hard to control given even a change of venue. This is a tough one without direct direction. But Im listening. ;]
Mags
Magluvin
Quote from: LtBolo on February 18, 2011, 10:10:33 PM
I agree..  Electrons can be very fast traveling.  But when we consider normal everyday simple electricity/electronics, a good bit of the electron flow would be considered slow.  I get the concept, it would be cool to see a demonstration or a realistic sim on the subject.
I can see where some may think that from what they have been told that they may see that the electrons move at the speed of light. I only in recent years came to the understanding that they dont, and the water in the pipe is a good analogy.  Like a garden hose with a nozzle. If the nozzle has resistance, then the water spraying out may have more speed than what is CURRENTLY running through the hose, but the amount per cu in will be different.
Mags
Mag
