0 Members and 141 Guests are viewing this topic.
quarktoo
Quote from: Magluvin on February 18, 2011, 10:27:39 PM
I agree..  Electrons can be very fast traveling.  But when we consider normal everyday simple electricity/electronics, a good bit of the electron flow would be considered slow.  I get the concept, it would be cool to see a demonstration or a realistic sim on the subject.
I can see where some may think that from what they have been told that they may see that the electrons move at the speed of light. I only in recent years came to the understanding that they dont, and the water in the pipe is a good analogy.  Like a garden hose with a nozzle. If the nozzle has resistance, then the water spraying out may have more speed than what is CURRENTLY running through the hose, but the amount per cu in will be different.
Mags
Mag
Yeah.. The hose is the ground and where the water is flowing TO is the vacuum of voltage. I love how they program into the mindless how voltage is a positive charge to keep them confused.
If only there was some way of compressing one end of a coil with some sort of a one-way-valve... I would make mine out of copper due to it's superior corrosion resistance.  ;D
Then I would run a wire right up through the middle of that garden hose and call it the Kapandze lawn sprinkler.
You guys crack me up.
core
  Well I think I'm going to be eating crow. Some of my research as of late has me believing we are chasing a ghost. This whole TK device is being made out to be larger then life to hide the fact it could be very simple. Here is an interesting quote from an Energetic forum thread.
Originally Posted by Jbignes5
For your pleasure I am re introducing this subject.
http://www.free-energy-info.co.uk/DonSmith.html.................................................. .................................................. .........and that antenna when not shielded from the environment will interact with that environment. .................................................. .................................................. .....
Hello Jbignes5,
I searched for this information by Don L. Smith ... I can't tell you for how long. Thanks for this info'
Do you have any idea how potent a statement the above is ? This is probably where many folks give up or simply can't connect the dots.
... THINGS MUST BE PROPERLY SHIELDED ... and much MORE than that ... THE RIGHT THINGS MUST BE SHIELDED IN THE RIGHT WAYS ...
Again, thanks,
From here I ended up with Tesla patent#433,702. Reading this patent it appears that when 'bobbin A' is at maximum or near maximum current 'bobbin B' is at near or at it's minimum. So bobbin A creates a current via induction into bobbin B. But when bobbin B is at max current it induces a current in bobbin A which is near minimum. It has been mentioned before that TK spark gap may be an 'overload' device. This overload may be located on the bobbin A circuit. What would happen if both coils operated at resonance? How much power could be transferred back and forth? Turn Tesla patent 90 Deg. and it looks similar to TK's patent.
Take a look at the Tesla patent and my pictures below. Included also is a Hi res picture of the Turkish device. The coils appear to be wrapped and well spaced for a good reason. Each of Tariels devices appear to be 'set up' differently. All of them may be using shielding as described by Tesla but just different types.
Just some recent thoughts.
Respectfully,
Core
BTW - Problem with this is that the Tesla patent is from 1890. If the above is correct one has to ask 'Why did Tesla even start with the work on his Magnifying Transmitter' and spend so much time. Maybe the above is not correct.
quarktoo
Quote from: core on February 18, 2011, 10:44:41 PM
Hello Jbignes5,
Again, thanks,
Respectfully,
Core
Meanwhile all the Farraday cage sitting over the top of the coils to shield against all the EMP coming out one end of the coil goes unnoticed.
You need to buy some better smoke and mirrors. I have a friend in the business if you are interested. I never pay retail for smoke.  ;D
Magluvin
Yo quarktard   you know nothing more than anyone else here. Cut the crap.  I see above you have been warned.  These last 2 posts from you are your substitute for being the way you have been to most here? This is the last I will reply to your posts. Most of the last month, your posts are way off subject and mostly insulting. I will look forward to your dismissal soon enough by your own accord.
Mags
core
Quote from: quarktoo on February 18, 2011, 11:09:53 PM
The Farraday cage was  discussed but you missed it. The original opinion was that TK was stealing power from transmission lines. I'm sure you have seen this picture before.....right.
  I agree with Mags you have nothing but wise ass comments to say about everyone.  >:(
Core
