0 Members and 139 Guests are viewing this topic.
Yucca
@All,
If you want to make nice high Q aircore coils then this DOC has some great tips for DIY so you can get really high spec coils for very little money:
http://www.arrl.org/tis/info/pdf/9708033.pdf
bolt
Kapanadze and Don Smith are both Tesla systems. One is ELF and DS systems are generally HF. They are both highly correlated because they all work the same. Kapanadze has moved from ELF to HF in later systems as there is more OU energy available in higher frequency systems.
The thread has fallen into the usual false speculations as usual when speculation is not required. Don smith has patent many systems and the pdf's and circuits are ALL here  on this thread!
This is NOT the TPU thread where you have to guess, the systems are already published you only need to build them.
flathunter
Quote from: bolt on July 24, 2009, 05:25:10 PM
Where are the Don Smith Patents?  The only one i've seen is for the Don Sith/Kapanadze device (which I dont understand).  I havent seen any for Don smiths other devices (actually, i think theres one for the plasma tube on the freeenergy website).  Am I missing something?  D. Smith seems to have built lots of devices, so there must be a patent about....a google search gets me nowhere.  ???
Thanks for so much useful info Yucca.  You da man.
PARAV
Bolt:
I appreciate and thank you for staying with us, in leading us in the right direction.
I know Don Smith had many designs and patents . Sadly, it seems for some of us experimenters, it's just not enough information.
Not to be dismayed though, and speaking for myself , I can see  when working on a circuit that has been spoon fed to me by others, how one gets spoiled with accurate drawings , schematics and parts lists that others avail to us.
Sooo, I've started building two of the designs there as per your suggestions, and am now just waiting for a neon transformer and an isolation transformer plus a few other tidbits , like high voltage diodes etc.
In the mean time , please stay with us and I will start reporting my progress  as soon as I get these parts together and attempt to get some electrons flowing in the right directions.
Parav
jeanna
I had something interesting happen yesterday.
first for a bit of background,
1- I have a dozen stubblefield generators. These are induction coils. Some of mine have secondaries. I made various sizes and materials and cores etc.
2- I have been playing around with a joule thief for 6 months and using the secondaries wound from them to produce various effects like lighting many leds or fluoro tubes for hours and pushing their design to see what they will do.
From before the start of this thread, I have thought the joule thief with secondary had the potential to replace the sparking induction coil.
So, yesterday, inspired by this thread and the thoughts of radiance and tesla's uncharted circuits, I put a few of my things together.
I had other plans but this is what happened:
I connected the secondary of a step-up stubblefield generator to my scope probes, and I turned on the scope.
Then I put the battery to the compound joule thief.
The stubblefield coil was still not connected to the joule thief, and,
I got a wave.
It was only about 100mv, but it was all radiant, and I was not even touching any of it to ground it.
The airborn oscillations of the area around the joule thief were enough to set the stubblefield generator in motion.
I want to encourage anybody to keep up with this work here. It has a lot of merit and will lead us to our goals.
One of mine is quiet, so I am thrilled to see 100mV from one transistor passing radiant energy through the air.
For me the next thing is to match these elements. Pulling things out of a shoebox and seeing them work is only the proof of concept. Now, the real work begins.
But, now I KNOW it IS possible to do this circuit with a transistor.
I made 2 videos to show this.
Each is 2 1/2 minutes long.
If you would like to watch them, here are the links:
http://www.youtube.com/watch?v=D_wAsAeUIHA
first radiantjt
http://www.youtube.com/watch?v=C9ZFKDSxFTE
second Radiant
enjoy,
jeanna
