0 Members and 123 Guests are viewing this topic.
core
Quote from: dllabarre on March 02, 2011, 01:42:43 AM
Another angle of 2nd wire from green box??
DonL
Don,
It does look like that wire runs around the bottom half of the coil then is 'skinned' back and into the copper tube. A splice point appears to be covered by tape. On some angles it looks like the 'insulation' of the wire is connected to the 'outside' of the copper tube. Eric Dollard does say that 'insulators' are the true electrical conductors.
Leo48,
Is that a 2000v volt AC meter? It has the same voltage scale on the top and bottom. TK appears to have it on the 1000v or (2000v max) scale. At one point, in the same clip prior to my screen shot, the meter reads overloaded (OL). It almost appears as if the 'load' wire is a negative voltage but when connected to a good ground will show positive voltage.  ???
Respectfully,
Core
leo48
This is my clamp meter the measuring 750 Volt AC and 1000 Volt DC  with wire red and black
and 200 & 1000 Ampere with clamp in two scales in one display with 4 digit and sign.
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
forest
Those pictures of green box from a few angles is important discovery ! I'm now sure that upper blue HV wire is connected to the end of thick copper few turns coil . That clears very common mistake ! the stiff wire coming from the bottom of coil is not connected to the thick copper coil but either to green box or to the inside coil.
Bizzy
Just a random question... has anyone (other than the people in the video) ever built a Kapanadze unit?
Bizzy
