0 Members and 90 Guests are viewing this topic.
dole
Hi,
It is a long time since I wrote something here. So I may be pleased to do that.
Once a while I decide to prove some theories, so I shoot photo with a two equal cameras against each other,
triggering shoot with flash in the same time (light collision), to my astonishment it worked.
Picture showed both objects in the same time, the wall behind and the person in front in whole.
We could see through the objects…
But anyway I may see what may be in the GB now.
So I wrote a small riddle :)
If you say clockwise I say counter,
If you say high I say low,
If you say fast I say slow.
d.
xenomorphlabs
Quote from: forest on March 02, 2011, 12:01:13 PM
See.
@ forest.
Maybe the red output wire is soldered to the thick coil.
There is "something" red visible being connected to it for some purpose.
quarktoo
Quote from: dole on March 03, 2011, 10:27:14 AM
Hi,
d.
I like riddles.
Hi Dole,
Glad to see you back. You have been busy and I have followed your progress on your youtube channel.
Your Kapanadze replication is quite nice but a little confusing.
The spool of black wire under the coil. Are you tilting the field or did you just not want to cut that expensive neon sign wire?
The black wire on the coil. Is that neon sign wire or did you fill a rubber tube with gas?
Here is my answer to your riddle from which Vladimir Utkin was kind enough to share. I also took a screen shot of your gas tube video to compare. VERY NICE!!!
I assume there is a doorknob capacitor separating two counter would coils
core
d.
So if you say Electric I say Die-Electric.
Maybe you found out why CosmoLV liked Holograms.
Respectfully,
Core
quarktoo
A Poem to Dole
To my friend Dole, I have a question.
You used red tubing, was that a suggestion?
I would have thought green tube would be a better choice.
Those atoms speak, with eight times the voice.
Maybe it was red and maybe it was green.
What if we used both, would a potential difference be seen?
Those LEMW waves are interesting to see.
Thank you for sharing your information with me.
I am your student and have learned a great deal.
Separating fact from the illusion and what is real.
