0 Members and 46 Guests are viewing this topic.
grizli
Quote from: baroutologos on March 31, 2011, 09:04:17 AM
Hehe... nice.
i was reading the post re-puplication of yours of buzz sayings regarding Kapanadze and i found of interest there talking about a kind of transformer resembling Zatsarinia's one, being sinle turn or better a wire being house by a ferrite tube etc commonly know as coaxial transformers used in HF applications.
In regard to this, Buzz claimed that is possible to have a non inductive ??? transformer yet able to pass power from a wire to next to it being not reflected to the source? I have no little knowledge tot that. Can he elaborate what he meant by that? (the post was a bit messy in technical or replication terms)
http://home.earthlink.net/~christrask/TraskTLTTutorial.pdf
Transmission line transformer,
Lower frequencies works like classic one (ferrite) , higher like transmission line
grizli
Quote from: dole on March 31, 2011, 10:54:33 AM
No problem, I use copper tub or/and twisted copper cable as a primary and an insulated
or bare copper wire as the secondary wound on a ferrite core tube of rings
or a paper tube.
But it will be more correct to take this from original text:
“by the proper design of a comparatively small and compact transformer. In carrying on tests
with a secondary in the form of a flat spiral, as illustrated in my patents, the absence of streamers surprised me,
and it was not long before I discovered that this was due to the position of the turns and their mutual action.
Profiting from this observation I resorted to the use of a high tension conductor with turns of considerable diameter
sufficiently separated to keep down the distributed capacity, while at the same time preventing
undue accumulation of the charge at any point.”
And then I use water/oil homemade leyden jar and lately Doorknob capacitors but
I must admit that I am back to the leyden jar since I can make small adjust in capacity to.
For those further interested I will copy this to, from the original writings:
"I have been asked by the ELECTRICAL EXPERIMENTER to be quite explicit on this subject so
that my young friends among the readers of the magazine will clearly understand the construction
and operation of my "Magnifying Transmitter" and the purposes for which it is intended. Well,
then, in the first place, it is a resonant transformer with a secondary in which the parts, charged to
a high potential, are of considerable area and arranged in space along ideal enveloping surfaces
of very large radii of curvature, and at proper distances from one another thereby insuring a small
electric surface density everywhere so that no leak can occur even if the conductor is bare. It is
suitable for any frequency, from a few to many thousands of cycles per second, and can be used
in the production of currents of tremendous volume and moderate pressure, or of smaller
amperage and immense electromotive force. The maximum electric tension is merely dependent
on the curvature of the surfaces on which the charged elements are situated and the area of the
latter."
So when this is understood, it become clearly obvious, that principally any combination is possible.
d.
Image would be nice?
So this is not classic TC if you use ferrite? Ferrite lowers natural resonance frequency very much, and there is no standing voltage wave across TC secondary wire, like tesla says?
I am confused why many experimenters use ferrite core, this limits all that related to standing wave, and classic behaviour of Tesla coil.
This is Tesla original text quoted? can you link original source of text quoted
Thank You!
grizli
Quote from: scratchrobot on April 01, 2011, 10:40:32 AM
Just experimenting and this time i got some real change in brightness in bulb when injecting HV.
http://www.youtube.com/watch?v=gexmHe56thM
scratchrobot
Can you make schematics, what you did ?
So we can understand whats going on, thank you !
scratchrobot
Still waiting for my ML566 to arrive  >:(
Some pdf on the chip.
link
link
TEKTRON
Quote from: scratchrobot on April 01, 2011, 01:58:54 PM
link
link
Scratch, I think it was said 566 was a misprint. I think it should be 556???
