0 Members and 89 Guests are viewing this topic.
ramset
Bill [Moderator]
Stefan saves Movies for us all the time!!
Do you know how to save this to a file?
http://www.youtube.com/watch?v=zg8V9XCgIqs
Thank you for posting the Movie Wesley!
Chet
Thanks Grandma
Pirate88179
Chet:
Sad to say, I do not.  Unless you mean to an upload file which anyone can do.  (Although, I have never done that either.)
dllabarre
Quote from: ramset on April 03, 2011, 11:25:43 AM
Chet
I use www.clipconverter.cc to save (download) many different type of movies including youtube movies.
It's free to use!
DonL
stivep
Bill [Moderator]
Chet
To save video I use
RealPlayer Plus
but you can also use another very good set of programs:
Your Software Status
Replay Media Catcher 4.1.1
Update to version 4.1.6
Replay Video Capture 4.2
Replay Music 3.98
Replay AV 8.82
Replay Converter 4.07
Replay Media Splitter 1.9.1012
Video Padlock 1.14
Replay Telecorder 1.2.0.4
I think it is even better Than RealPlayer that presses you to upgrade
cosing problems after any new upgrade they  make.
(Than you see that your ability to upload Youtube is no longer
till you load upgrade  that cost you money)
Wesley
http://citeseerx.ist.psu.edu/viewdoc/download?doi=10.1.1.30.2312&rep=rep1&type=pdf
Scrathrobot thank you this is very useful:
http://www.docin.com/p-113420406.html
or in different format:
http://books.google.com/books?hl=en&lr=&id=eKUnQrTy-S0C&oi=fnd&pg=PR7&dq=ferroelectric+devices+uchino&ots=hjuEJYKqlc&sig=PU2gsYCjRUg0RdhUgWUnqpYofO4#v=onepage&q&f=false
it gives you  frequency response and behavior of ferroelectric capacitor
Very interesting PDF
explaining
1.Frequency response of ferroelectric capacitors
2.why ferromaterial with permanent dipoles can NOT be used in microwaves
3. permitivities are at low KHz
4.Permanent dipole reorientation can flow only at MHZ-GHz
5. ferroelectric capacitors can store more electric charge due to dielectric polarization.
6. explanation how elastic energy(Vclas) and dipole interaction (Vdip) combine equals total energyV(tot)
CAN ANYONE TELL ME why!!!!
THE PROJECT IS SPONSORED BY DEPARTMENT OF DEFENSE ?
http://www.femuri.caltech.edu/
i THINK WE RELAY  HAVE GOT SOMETHING HERE!!!
http://www.intechopen.com/articles/show/title/electronically-tunable-ferroelectric-devices-for-microwave-applications
IN THIS TEXT YOU WILL FIND INFO THAT :
ferroelectric  capacitors can withstand 1000ts of  Volts and   they are tunable electronically.
http://www.intechopen.com/articles/show/title/electronically-tunable-ferroelectric-devices-for-microwave-applications.
fabrication of ferroelectric materials:
http://apl.aip.org/resource/1/applab/v93/i23/p233109_s1?bypassSSO=1
http://www.nsti.org/publications/MSM/99/pdf/W4201.pdf
simulation of ferroelectric capacitor
http://www.nature.com/nnano/journal/v5/n2/abs/nnano.2009.451.html
Electric-field control over domain structure allows the photovoltaic effect to be reversed in polarity or turned off. This new degree of control, and the high voltages produced, may find application in optoelectronic devices.
Controversy:
http://portal.acm.org/citation.cfm?id=1457844&dl=ACM&coll=DL&CFID=14795419&CFTOKEN=99174230
Ferrites, ferroelectric capacitors, and some ferromagnetic materials all possess bulk characteristics which are usually referred to as square-loop properties. It has been recognized for some time that these properties are particularly compatible with digital-device requirements.
.. In addition, it introduces an equivalent circuit model of the devices to determine some of their attributes and limitations. The model is essentially a nonlinear resistive and reactive network whose parameters are determined by the internal state of the device and by its present state of excitation. .., the discussion will be limited to magnetic devices. .....direct ferroelectric equivalent exists for multiple-aperture magnetic devices.
.... Optimal results have been obtained with a driving (i.e., reference) signal of 10 V at 100 Hz, which was used to polarize the device.
.... nonlinear behavior of a coupled oscillator system wherein the active (nonlinear) elements are the ferroelectric capacitors
http://www.informaworld.com/smpp/content~db=all~content=a714457987
Frozen domains
.....few frozen a-domains significantly degrade the hysteresis...
...Strange behavior in the shift of hysteresis loops can be also explained by this model. ....
Condensed Matter !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
http://iopscience.iop.org/0953-8984/22/5/055901;jsessionid=88C6999712EBE5B92078E65EEDAAF305.c1
Effect of manganese doping on the size effect of lead zirconate titanate thin films and the extrinsic nature of 'dead layers'
Ferro electricity:
Phase field simulation of the switching process in a ferroelectric - PFM-type geometry
VIDEOhttp://www.youtube.com/watch?v=qMnkTqlqPPo&feature=player_embedded
Square loop magnetic logic circuits
Very interesting with scope shots.
http://origin-www.computer.org/plugins/dl/pdf/proceedings/afips/1959/5054/00/50540047.pdf?template=1&loginState=1&userData=anonymous-IP%253A%253AAddress%253A%2B74.73.64.238%252C%2B%255B172.16.161.5%252C%2B74.73.64.
http://www.patents.com/us-7149137.html
Process monitoring for ferroelectric memory devices with in-line retention test
Abstract
The present invention facilitates evaluation of ferroelectric memory devices. A ferroelectric memory device is fabricated that comprises memory cells comprising ferroelectric capacitors (802). A short delay polarization value is obtained (804) by writing a data value, performing a short delay, and reading the data value. A long delay polarization value is obtained (806) by again writing the data value, performing a long delay, and again reading the data value. The short delay and long delay polarization values are compared (808) to obtain a data retention lifetime for the ferroelectric memory device. The obtained data retention lifetime is compared with acceptable values (810) and, if deemed unacceptable, avoids unnecessary performance of thermal bake data retention lifetime testing.
Inventors:   Rodriguez; John Anthony (Richardson, TX), Bailey; Richard Allen (Colorado Springs, CO)
Assignee:   Texas Instruments Incorporated (Dallas, TX)
Appl. No.:   11/027,221
Filed:   December 30, 2004
http://adsabs.harvard.edu/abs/1998ApPhL..73.2838J
NASA
Giant effective pyroelectric coefficients from graded ferroelectric devices
Jin, F.; Auner, G. W.; Naik, R.; Schubring, N. W.; Mantese, J. V.; Catalan, A. B.; Micheli, A. L.
Applied Physics Letters, Volume 73, Issue 19, id. 2838 (1998).
Effective pyroelectric coefficients as large as 5 μC/cm2 °C, with peak responsivities at approximately 50 °C, were obtained from compositionally graded barium strontium titanate ferroelectric thin film devices formed on silicon using unbalanced magnetron sputter deposition. These effective pyroelectric coefficients are nearly two orders of magnitude larger than those observed from conventional pyroelectric thin film ferroelectric detectors.
Coexistence of ferroelectricity and antiferroelectricity in epitaxial PbZrO3
films with different orientations
http://www.mpi-halle.mpg.de/mpi/publi/pdf/7914_08.pdf
worth reading:very delicate conspiracy theoretical divagation
http://www.publish.csiro.au/?act=view_file&file_id=PH98094.pdf
Australian Journal
of Physics
History of ferroelectric:
http://www.ieee-uffc.org/main/history/cross_newnham.pdf
More controversy:
http://bariumtitanate.blogspot.com/2008/07/reader-zawy-on-eestor-purity.html  Revolution begins with Electric Cars?
New electronic element MEMISTOR
http://www.nature.com/news/2008/080430/full/news.2008.789.html
this is  kin of shocking:
http://docs.google.com/viewer?a=v&q=cache:wlmaQElO8CEJ:www.stealthskater.com/Documents/Consciousness_15.pdf+controversy+ferroelectric+capacitor&hl=en&gl=us&pid=bl&srcid=ADGEESh3zHJv5Ow0mVM7YY8WI2b0Mvxnjtlt8zOCcBYMJ3oRNGStGKWGqhpbnpp8IZEnwUu716DaA9anImr4w7EAJoe8iYKWh7Jehtv3lKH-N7-f2l6VaGOa8aAleJl40VFvLmBg54vc&sig=AHIEtbTlSXbt0zeOCPg2XABChe1-sAAw1w
or
http://www.stealthskater.com/Documents/Consciousness_15.pdf
http://www.ferrodevices.com/1/297/radiant_edu.asp
Radiant EDU
they even  created tool to visualize hysteresis of ferroelectric material
The EDU a unique educational tool for science and engineering education. The EDU is a fully functional test instrument for the non-linear electro ceramics like those used for industrial sensors and actuators. The EDU measures the hysteresis loops of packaged ferroelectric capacitors Radiant created specifically for the tester. Radiant provides a complete set of tutorials to guide the student in understanding non-linear materials and a set of recommended experiments for the students to work with the ferroelectric capacitors. External ports on the instrument allow students to build their own sensor and/or memory projects using ferroelectric components from Radiant and to control their projects using the EDU’s operating software.
The EDU has a 20kHz arbitrary waveform generator and a 20kHz electrometer that run under the control of an elegant graphical data-acquisition program. The EDU architecture allows any laptop with a USB port to become a ferroelectric test instrument in less than a minute, making it a perfect teaching tool in student labs.
Was not that .that SR was using 20-35KHz?
"We are going to get them by the balls"
New Details of Ferroelectric Switching
http://www.aps.anl.gov/Science/Highlights/2004/ferroelectric_switching.htm
1."X-rays penetrate right through materials, so we can look deep inside electronic devices,
Question:Do we deal with some of Xray efect or ultraviolet efect  when we use spark?
2.Polarization fatigue is a well known problem in ferroelectric capacitor technology. In this case, the effect is believed to stem from migration of oxygen atoms to the electrode region
polarization fatigue was qualitatively different when the switching was driven by lower-amplitude electric-field pulses (0.625 MV per cm peak) switching versus higher field pulses (1.2 MV per cm peak). Fatigue was observed in both regimes as the polarization-field hysteresis loops collapsed after repeated cycling with triangle wave pulses at 1 kHz. Low electric field fatigue was observed within 104 pulses as the PZT layer structure became pinned into an unswitchable state, which could be restored by exposure to higher field pulses.
Do we deal with TK using frequency of supposedly 50Hz to 800KHz ?
and project was sponsored by:U.S. Department of Energy
(grant numbers DE-FG02-03ER46023 and DEFG02- 00ER15031)
Use of the Advanced Photon Source
was supported by the U.S. Department of Energy,
Office of Science, Office of Basic Energy
Sciences under Contract no. W-31-109-ENG-38).
