0 Members and 258 Guests are viewing this topic.
ramset
OK
I got Mish mosh in my Email acc't
What I posted yesterday was part of "this" that I just found 5 min ago,
And Core If you read my post again RE ;COP 25
You will realize why no one has asked ""ME""
About the COP 25
They have to ask this Guy..............
Quote:
http://www.doitpoms.ac.uk/tlplib/ferroelectrics/index.php
Wesley's comments about ferro-electric effect in the SR 193 device are correct. He claims that Kapanadze does NOT use ferrite but he does not know what is in the copper tube coils or under them IMO. The ground wire running through the center is a dead givaway that ferro effect is also being exploited by kapanadze. I get a massive energy transfer to that ground wire when it is all working properly.
The right ferrite material is difficult to find. I found about 100 of them and bought it all. You will know when you have the correct stuff because if you put a 1 turn coil around it, it will sing from piezo electric effect if the coil is driven by a zero resistance resonant circuit. I just built a circuit on a breadboard powered by a 9 volt battery and took that to surplus shops and got lucky and found the right stuff. Don't have a part number of where it came from as it was surplus but when I crush it into fine powder, it looks like broken glass so it must have a large amount of silicone dioxide in it. Out of 100 different parts tested, two parts had the effect. Iron power is useless and I see some people trying to use that thinking it is ferrite.
BEMF is what triggers the effect from my experiments. Any resistance will kill the effect. Maybe it is multiple non-linear resonances producing a bunch of BEMF.
Dole's quote regarding Tesla and multiple resonances is also correct in his "The Lie" video.
Not sure if that helps but that is my experience and it is rock solid info based on a month of experiments trying everything I could think of.
Lastly, cold electricity is all about standing wave and BEMF. People should first find the correct ferrite material and then build a cold electricity circuit which Dole vaguely supplied at about page 250 and then play with the ferrite. The modulation coil does not need to be powerful and lots of different things would work including a simple H-bridge driver. I think you are looking for three separate resonances on the same coil.
I am still working on the gas / vacuum properties and am finding some strange stuff I can't explain but then it took me weeks to figure out that the ground through the center thing was ferro electric effect energy transfer.
I'll get there with or without D ,I don't suppress OU info.
Feel free to share that truthful and tested information. Amidon could probably point you at the right ferrite if they actually answered their emails.
Somewhere on youtube is a good resonant circuit and a demonstration of the effect. I'll look for it some more later. That effect is key to replicating this device.
Thanks Grandma
AbbaRue
Hi, I haven't posted on this forum for a long time, and wanted to let all know I am attempting to replicate this unit as well.  I've been trying different size coil arrangements and I'm using 10 x 300 watt Halogen tubes for my load.  So far I haven't got anything unusual to report yet. If I do I will let you know.
MiniMinion
Quote from: AbbaRue on April 04, 2011, 06:08:35 PM
Have a look at what Westley wrote the other day regarding square wave caps and peize ferro electric effect. This goes back to Norm Wootan and he was clearly suppressed.
SR193 wrote a small piece about how domains can be aligned in some ferrite materials. I have found this to be true as well. What I have been able to confirm so far is that back EMF is what is triggering that magnetic moment.
While I can't be absolutely sure, I think at one time Umbrella tech held a technology that harvested back EMF from power lines, used that to charge nickle iron batteries and then fed that back into the grid. That website or one of their subsidiaries talks about making the grid 40% more efficient. This is just about what I recall that invention claiming. Someone may have a link to what I am describing.
The next thing I found was that when you run a wire through the center of a stack of the right ferrites with a lot of back EMF and zero resistance , there is an incredible energy transfer to another conductor. You see BOTH Kapanadze and SR193 doing this with the ground wire and I have never seen a coil wound that way before. This appears to be an effect that has been and is currently being suppressed. I am planning to release a simple circuit with some photos to demonstrate that later today.
Lastly you see copper tube used in the Kapanadze device. You see Dole has sealed up the ends of his copper tune in some of his demonstrations including one with plastic tubing to the coil. You can get multipacitor effect and the gas and pressure / vacuum change the amount of electron cascade you reap.
This is what this site and others seem to be suppressing but hey have a closer look at the hubbard coil and you will see that copper tubing and how in the notes they packed ferrite around the tubing.
This may be the holy grail of OU device techniques and it is clearly being suppressed by people here. They are working real hard to make sure you believe there is no ferrite and there is no gas and using every trick in the book to deceive you.
Good luck with your project and I hope you keep sharing anything you learn even if they delete it over and over.
hartiberlin
Well, this what he calls Stanley Meyer Magnegas
thing is indeed a rotating gas core claimed ou transformer from
Stanley Meyer and has nothing to do with
the production of Magnegas...!
As Magnegas is only produced by burning coal or graphite
under water, this has nothing to do with this toroidal
rotating gas core transformer of Stanley Meyer.
So you see,
TheBuzz is twisting all the things...
Maybe he is on drugs ?
Well, just let him rave there...
Also make people curious to look for the real messages
here at overunity.com
Regards, Stefan.
Shokac
