0 Members and 487 Guests are viewing this topic.
MrPayback
Quote from: LtBolo on April 14, 2011, 11:11:40 PM
I was experimenting on the theory that SR was using a spark discharge to vibrate the ferrite molecules, which lowered the permeability of the ferrite, thus increasing current per 0.5dLi^2. I was not so very interested in what frequency the ferrite was resonating, but that it simply was resonating, and while doing so permeability dropped.
After lots of time in the lab, I was never able to prove that permeability dropped, so I discontinued the line of experimentation. The sad thing was that it made so dang much sense as a theory. I will not blindly chase something however, and unless I have a very good reason to believe that a theory is true, I'll stop pretty quickly if I don't get experimental validation. I didn't.
The only thing I was able to prove conclusively is that ferrite saturates pretty quickly when sparked, but I'm pretty sure that wasn't news.
I tend to look at the work of others, compare it to people doing the same thing and then look for a pattern.
On the SR device video where he shows you his HV base layer coil, you see two different colored wires but do not see if they are physically connected together.
It would be silly to think that he used two different colored wires and then connected them together as some have suggested. That is not the type of construction they do - think like the inventor you are researching. They build things like they are working at gunpoint. Fast and messy.
Those wires connect to something in the center. He drew a plate or tube on one side of the coil. He also would not have done that for no reason.
So your theory was probably wrong based on what can be observed visually. It appears to be an inductive / capacitive link between the two coil halves and the core material. (Electron extraction)
Due to the fact that there is a foil sheet under that coil, the fields will be bent or distorted. That can be useful based on my experiments. Again... Utkin.
LtBolo
Quote from: MrPayback on April 14, 2011, 11:55:01 PM
There were other reasons for the theory. I won't drag it up again, but certain folks claimed that they had specific knowledge that parameter change (delta L) was what was happening. Beyond that I have no clue whatsoever as to what SR was doing.
Bent? Distorted? I don't think so. The permeability of non-ferrous metals is effectively that of air. I had concluded that he was using the foils to create an electrostatic field across to the ferrite to effect the parameter change. But as I mentioned before, I couldn't prove that. There are certain ceramics that change permeability in an electric field. It may be that the ferrite SR used does that. Without more specific knowledge this becomes a very frustrating endeavor.
Which led me to the point that I quit trying. Giving that the guys that have succeeded may not even know why their devices really work, the odds of randomly hitting it are pretty small. I am holding out hope that eventually somebody will do the selfless thing...
MrPayback
Quote from: LtBolo on April 15, 2011, 12:07:55 AM
Those non-ferrous metals become quite magnetic in a changing magnetic field and as such, distort the field. Permeability is irrelevant.
Quote from: LtBolo on April 15, 2011, 12:07:55 AMI am holding out hope that eventually somebody will do the selfless thing...
That would be suicide. What people can do is work together and share their knowledge as they go. I would encourage you to do that. That way when we get there, we all get there together and there is safety in numbers.
Some ferrites exhibit peizo electric effect induced by what I think is Lentz force which is orthogonal to the direction of current flow. This is displacement current? Correct me if I am wrong.
The 1 turn coil running through the center of the device is something that needs to be fully understood. The Earth ground requirement is another part that needs to be understood. The combination of the these components seems to be what is needed to break the symmetry.
The oak tree is not felled with one mighty swing of the axe. It is many little chips. It takes time and patience. If you are waiting for someone to do the selfless thing, I hope you are a young man. Be the change you want to see in the world.
cosmoLV
Quote from: iceweller on April 14, 2011, 07:43:21 PM
   Cosmo, any feedback on the "hidden" component under the flyback (SR)?
i have to say that soon i release schematics and ReadMe file how stuff works in all possible forums around the world to be sure it not disappear somewhere ;)
But in device is not much about schematics and electronics, there are more important stuff about connecting all coils and wires to make electricity flow in right directions â€" in device is not Over Unity, but there are something different "OverUnity is exotic name" and it is not the right name for this device it is only visual feel about this fact, in real this device do something what is not OU but something different, it is hard to understand what i say you, but it is True
Keep your chakras opened :)
forest
Cosmo
does  it work like ferrite antenna  by radio waves ?
