0 Members and 609 Guests are viewing this topic.
MrPayback
Quote from: LtBolo on April 19, 2011, 11:22:01 AM
Not even sure I remember. ;)
I see 3 possibilities for the ferrite.
1. Per the Michel Meyer-Mace patent, Fe56 to Fe54 transmutation with release of power.
2. Per Dollard, power generation through change in inductance due to ferro-resonance or other disruption of the ferrite medium via electrostatic or magnetic action caused by a spark discharge.
3. Per Stiffler, an antenna to gather cohered energy.
If I recall, Cosmo suggested #1 and #2 at different times and in different ways. It seems pretty obvious that #1 above would likely result in degradation of the medium eventually. No clue how long. And I think I recall Cosmo expressing frustration when someone cited the Michel Meyer-Mace patent...thus violating 'Dress Code' by revealing too much. And I'm pretty sure I remember a reference to parameter change at some point, which is #2 above. It's all a bit fuzzy at this point though.
Personally, I am on the broadband energy coherence bandwagon right now. That would explain a number of devices very nicely, does not require ferrite (although it can play a role), explains the need for either a spark or very sharp edges, it uses resonance but not necessarily in the way it is normally thought of, explains the need for bifilar coils, and a handful of other things.
There is one more possibility and unfortunately it is original. This of course makes me a larger target than normal. Fire away dependtards and spooks.
Ferrite originally consisted of magnetite (Fe2O3). The oxygen atom is but a small handful of polarized atoms and as you can see, the odd number of oxygen atoms creates an opportunity for a magnetic molecule. Do all ferrite materials will contain an ODD NUMBER of Oxygen atoms?
Last time I tried to explain this I got banned and the posts were instantly deleted by the usual suspects. I have copies of the posts to back that claim up.
Meyer claimed he "was doing the exact opposite" of electrolysis. That would be reverse electrolysis. This takes us into the cold electricity and if you look at Meyer's coils, you see how he shorted the primary to the secondary on the other side of the toroid. This of course destroys the positive energy and allows negative energy to fill that space for a moment. (Cold electricity)
Your explanation of cold electricity does not work for me. There are thermal, acceleration / propagation, transmute and reverse time issues that are not explained by such a simplistic explanation.
Explore the possibility that after oxygen depletion the core material simply needs to go through oxygen renormalization process since the oxygen atom is the actual fuel. Atomic batteries need to be recharged with mass.
EV Gray had a tube from the engine to his electric motor - Carbon Monoxide? ( - Odd number of oxygen atoms) Kapanadze has clearly figured out magnetohydrodynamic effect (The generator in the plexiglass tank of water video on his youtube channel)
LtBolo's question: "Where does FE come from, and how does it get from there to here?"
It comes from the conversion of mass into the atomic energy contained in the mass. It gets from there to here through acceleration - no exceptions. Feel free to prove me wrong, you will be the first.
The cavitation of the spark gap IS AN ACCELERATION METHOD or "implementation method" and that is everything. The counter wound coil is also a magnetic accelerator / cavitator of sorts.
I tend to agree with you that people don't understand the process - Good luck with your mission.
Alternative answer #2 in case you are bored like me:
FE comes from eBay and it gets from there to here via UPS.
You can buy a free energy device for less than $500 dollars online right now and in a million years I would not disclose where on this web site. I am like Friedrich Nietzsche - I hate everyone. ;-)
Here are some of my favorite Nietzsche quotes:
[ Me ]
"The individual has always had to struggle to keep from being overwhelmed by the tribe. If you try it, you will be lonely often, and sometimes frightened. But no price is too high to pay for the privilege of owning yourself." - Friedrich Nietzsche
[ LtBolo and Dole ]
"In heaven all the interesting people are missing." - Friedrich Nietzsche
[ Pirate and Core ]
"To predict the behavior of ordinary people in advance, you only have to assume that they will always try to escape a disagreeable situation with the smallest possible expenditure of intelligence." -     Friedrich Nietzsche
[ Cosmo and Stivep ]
"Insanity in individuals is something rare - but in groups, parties, nations and epochs, it is the rule." -  Friedrich Nietzsche
forest
Could that ferrite degradation be caused by eddy currents and heat ?
ramset
MrPayBack
Thanks for the Pic
So no Ebay Link? >:(
Hows about a simple "How to" On the lightbulb circuit?
NEETZY Huh? [such a nice man]
Core
"Everybody be ready on june 20th"
HHMMmmmm
"Roll on June 20th" ,Where have I heard that before?[could Cosmo be Archer ??]
Personally I hope we get something interesting rolling before then!
X
Thanks Grandma
LtBolo
Quote from: MrPayback on April 19, 2011, 01:23:39 PM
I wasn't explaining cold electricity. I haven't personally witnessed anything that required such an exotic explanation. I was saying simply that most things attributed to cold electricity do not require anything like that. Most of the effects that folks attribute to cold electricity can be explained by high frequency.
That said, I wouldn't be the slightest bit surprised that there are other particles, other than electrons, flowing in the wire that can have alternative attributes. If anyone knows of an experiment to create such a thing, I would love to perform it.
LtBolo
Quote from: forest on April 19, 2011, 01:45:51 AM
Why ? Did you found the reason for degradation ? Did you found dangerous radiation from ferrite ?
If it is a variant of the Meyer-Mace technology, the Fe56 contained in the ferrite is being converted to Fe54. The process of that will inevitably release particles. The Fe54 is radioactive, but is so stable that it is safe. The bigger problem would be the initial particle release.
As for degrading, doing the math on the Meyer-Mace technology yields a bunch of power for a small amount of iron. I would think you could power a house for a year for few dollars worth of iron, so I'm not sure that I think that is any reason not to pursue it.
