0 Members and 928 Guests are viewing this topic.
Bruce_TPU
Quote from: Shokac on May 27, 2011, 07:41:52 AM
Oxygen is the same gas!  :)
Watch
http://www.youtube.com/watch?v=azQSMhWco8Y
Oxygen is very flammable, and mixed with HV, mini "Boom!"  Oxygen is atomic number 8.  So.o.o better would be Nitrogen, which is "inert" or non flammable and 70 percent of our atmosphere is made up of the stuff, or neon, which is atomic number 10.  Or, make your own with sodium, also inert, at atomic number 11.
I would still run a low resistance wire to ground, for negative electrons.  Would improve output dramatically I believe.  Flow is Negative to positive.  So the more negative electrons available, the greater the output.  The "earth" would have a limitless supply.
Cheers,
Bruce
EDIT:An excerpt taken from Rex Research:
Further evidence of the need for a limitless flow of negative electrons.  This is the same source of fuel for the TPU, but whose source is aluminum.
"One day, Barbara, my wife, and I witnessed a demonstration by Paulo and Alexandra Correa of this 'Aether Motor' - it was an electrical generating system that could deliver electrical power without any external power input save its connections to two 'orgone accumulator' boxes or to either our insulated bodies or a ground pipe. Since the device moved a motor and drove a circuitry, it had to consume some power; this appears to have been provided by the environment. The event occurred with incredible calm - no explosion, no noise even, no sudden heat, no bright light, just the quiet pulsation of a discharge tube and a quiet turning of a small rotor. Save for the driving of the motor from contact with our bodies, the effect was almost disappointingly banal. It has not always been that way. There were occasions during the evolution of these discoveries when accidental electrical discharges did threaten the lives of our intrepid pair. Fortunately, these accidents never deterred them."
Shokac
"Tariel says: make ТТ in resonance and you will see immediately all is in front you eyes"
What to see?
Answer...
See ozone and strong magnetic field.
I think this is the right way to free energy!
Look:
Shokac
Quote from: Bruce_TPU on May 27, 2011, 12:26:36 PM
Cheers,
Bruce
Bruce, I agree with you, but oxygen is sufficient:
Shokac
Look this Kapanadze pattent:
Negativ is conected only to source and to ground, but positive conected to coil (free ions maker) and collect free electrons from air with HV discharged or from ozon coil tube.
Free electrons maker is AC HV, but out is DC 300-400V.
Now compare to witch vaccum tube.  ;)
