0 Members and 60 Guests are viewing this topic.
Shokac
Quote from: stivep on May 28, 2011, 12:05:02 PM
One of great people in this forum is Shocac.
This is the man I believe is the way  You all should be!!!!
Thank you Stivep!
Bruce_TPU
Quote from: Shokac on May 28, 2011, 09:24:51 AM
That is, in principle, was my idea.
It is still only have to prove it.
Hi Shokac,
When viewing these, think "surface area".  Mesh seems to work the best.  Aluminum mesh.
http://www.youtube.com/watch?v=PFQSXB5p_vQ&feature=related
http://www.youtube.com/watch?v=rJvb2tPzL9s&feature=related
http://www.bigclive.com/ozone.htm
Below is a picture I was thinking of this morning and wanted you to take a look...
Cheers,
Bruce
Shokac
Thanks Bruce
I see this staf long time ago.
Bat, ozone maker first make free electrons then free elektron with oxygen make ozone
O2+HV=O+O.
O+O2=O3
Proces take free elektrons before make ozone. No need spark gap. Kapanadze use spark gap for safety (Safety gap), or for make HI voltage (Tesla coil).
Spark gap no need in the proces for make free energy.
Shokac
Another proof is testatika.
The device also has an ozone generator.
from this site: http://www.rexresearch.com/testatik/testart.htm
* Testatika is not a perpetuum mobile, but an energy machine that collects it's huge amount of "FREE" energy from the charged and ionized air particles. But there are still some technological tricks implemented to overcome the normal drag-resistance of a conventional Wimhurst machine, which is still the secret of the Methernitha group !!!
Bruce_TPU
Quote from: Shokac on May 28, 2011, 03:52:11 PM
Thanks Bruce
O2+HV=O+O.
O+O2=O3
Ok!  So, like I had it yesterday.  A good place for folks to begin to experiment, I think.
Those links were more for others to see how easy ozone production is.   ;)
Cheers,
Bruce
