0 Members and 536 Guests are viewing this topic.
Cap-Z-ro
Is that 2 legs I see on the vac tube...and would one be ground and the other the battery's negative terminal ?
Regards...
electricme
@ Chokac,
This is a nice photo of the Vacuum tube and it,s acompanying components, may I ask you for the http address, I was wondering if there was any other info about it avaliable, maybe text etc?
jim
TEKTRON
Quote from: wings on May 30, 2011, 07:59:20 AM
http://tech.groups.yahoo.com/group/freeenergysurprise/
http://www.overunity.com/index.php?action=downloads;sa=myfiles;u=24846
FreeEnergySuprise.PDF
Description
The "Free Energy Surprise" researches possible Tesla-based
anomalous heat or electrical power from the environment. This
refers to an experiment proposed by William Lyne in a booklet prepared by him following the path of the "Free Energy Massacre" end chapter in his book "Occult Ether Physics".
In the downloads section you will find the documentation on how to replicate the experiment (permission from the author granted).
Bruce_TPU
Quote from: TEKTRON on May 31, 2011, 09:40:57 PM
Description
Hi TEKTRON,
Have you, or anyone you know, replicated this?
Cheers,
Bruce
TEKTRON
Quote from: Bruce_TPU on May 31, 2011, 10:37:31 PM
Hi TEKTRON,
Cheers,
Bruce
Not yet, but I was thinking it would be cheap to do. Maybe wrap some coils around it and see what happens ? ;D
